Question about Baby Gear
Automotive Glass installation
I am trying to reinstall the rear window on my 1955 Chevy Belair. I have a new seal but can not find any info as to how the seal goes on, nor how to install the glass once the seal is in place.
Can you help a car brother out?
    Genius:
  • 1,665 Answers
Put first rubber seal on the glass and fit a thin rope all around the seal with rope ends come out at middle downside. Let glass (with seal fitted on it) sit down side of car window, and pull rope ends from inside the car, while someone pushing the glass from outside to help seal fit on window edge.
Posted on Apr 03, 2008
How do l adjust the door on a 1955 chevy belair 2 door hard top
make sure pins are in good shape not sloppy but tight --then will need to loosen bolts and move door in out and back and forth till lines and gap are lined up you may also need to add or remove shims
Oct 26, 2016 | Cars & Trucks
When I want to shut off the engine it seen like it want to keep turning 1955 Chevy belair 235 engine
you need more lead in your fuel ! that's probably because it`s an old car it ran on much richer fuel than the unleaded that we have today ! if you want ....,turn the key off while its in drive , and it'll go right off , and then put it in park.... that way you'll save the clang and you can also purchase trick fuel ! i have a 64 Dodge Dart , i had same problem at one time . Phillip 76 stations carry trick fuel.
Jan 15, 2015 | Chevrolet 1955 Ertl Chevrolet Bel Air...
How to reseal a rear window on a 2006 vw beetle convertible
if you want to keep it cheap, go get some clear silicone and carefully use it to seal the gasket to the metal. if you want to do it correctly, any automotive glass shop should be able to fix it.
Aug 13, 2014 | 2005 Volkswagen New Beetle Convertible
Need to replace rear main seals 57 belair do you have to remove the engine
It is easiest to do with the engine out, but you should have enough clearance with frame crossmember to extract the pan. Number 1 cylinder may need to be at bottom dead center to clear the counterweights. And the center steering link may need to be removed. Pay careful attention to the oil pump and oil pickup at the rear of the engine.
You would loosen all of the main caps and allow the crank to drop about 1/8 of an inch. There is a tooth that holds the rope seal in place, so you need to be patient. There used to be a tool called a "Sneaky Pete" which was actually a couple tools made just for changing the rope seals with engine in the car. The loop with a tiny corkscrew end is the removal tool and dropping the crank that little bit allows the old seal to clear that retaiing tooth.
Soak the new rope seal in 30 weight oil overnight, and squeeze of excess. The graphite is supposed to be impregnated into the rope, and it is supposed to sit in the groove behind the "slinger" ring of the crankshaft. Form the new seal to the lower rear cap so it has the approximate shape to slip in along the groove. The other tool with a gripper claw grips onto the rope and the end with a loop is where the metal handle fits into. Feed the wire end with the gripper through the seal grove so it is hanging down, then clip the new seal to the teeth then slowly draw the seal into the groove. Rotating the crank as the seal is installed will help a lot. If the seal only goes in halfway and stops or tears off the gripper, the crankshaft needs to be lowered a little bit more. And try again.
Once the upper seal is in place, raise the crank back into place, put the new rope section in the lower bearing cap, and form it into the grooce and then trim the rope with maybe 1/64 to 1/32 of an inch showing..You want a slight amount of crush without it getting between the block and the bearing cap. The upper rope seal should be trimmed just proud of the block casting as well. The seal ends should remian clean, but you may want to put a smear of silicone on the back edge of the cap keep it away from the seal.and install the rear cap. and tighten just snug, rotate the crankshaft (always in the direction of normal rotation) a couple of times, and then torque all caps alternately. reinstall oil pump and install the pan after placing all gaskets in correct location and making sure the front and pan gasket pieces are not reversed with each other. Instal and tighten pan, and if the center link needed to be removed, reinstall it with new cotter pins.
When you do this, you need to watch the dampener to make sure that the radial rotation when loosening the caps does not dislodge the front seal or deform it.
If you use the rubber seal instead, the sneeky pete may or may not work for you because the tool was not made for the rubber lip seal.
With the rubber lip seal, the procedure is the same except keep the seal dry and clean as you will be putting only a slight dab of silicone on the ends. The rubber seal is supposed to sit staggered in relation the block machining, so one end will be out about 1/4 inch and the corrosponding offset should exist on the lower seal when installed, the seal ends are not in line with machined surface the cap bolts to.
Most importantly, make the lip is facing inward on both halves ( crankcase pressurizes from blow by, and if the lip faces inward, the pressure forces the lip tighter to the crankshaft making a better seal.
Oct 06, 2012 | Collectable Diecast Mercedes-Benz CLK DTM...
I have a 1955 chevy belair, 350 engine and 4 speed tranny...the tranny code is GM34 with the #'s 3925856. What typr tranny is it?...saginaw? muncey?
See if this helps: http://www.angelfire.com/fl4/pontiacdude428/tranny.html
If it does not, keep it for reference anyhow, you may need it later!
Feb 06, 2011 | Chevrolet Chevy Cars & Trucks
1957 chevy belair rear leaf spring instalation. does the short end go toward the front or rear
usually the short goes to the front, just in case measure the distance to the axle to the front eye
Nov 27, 2009 | Chevrolet Chevy Cars & Trucks
Rear sliding glass window
If u r going to buy a new one, instructions will be included, if u have plans to purchase a used one from a salvage yard, they aren't too difficult to install, the worst part is removing the old glass, and that's already done! Rubber glass seal around outside should be in place, put a rope inside the seal (where the glass will go) leaving a couple of feet or more hanging out at the end. Put the glass in between seal edges as much as you can w/out forcing. W/ a helper, slowly pull the rope out as u push the glass into the seal, the rope pulls back the seal so the glass can slide into the channel. If u have any trouble, don't insert the rope all the way around, this way more of the glass will fit in the rubber channel (seal). Good luck, let me know how it works for u. countrycurt0
Oct 09, 2008 | 2000 Dodge Dakota Quad Cab
Vent window repair.
To replace the window seal, you first have to remove the vent window assembly from the door. After it is removed, the nut and spring on the bottom of the window has to be removed. Then remove the glass and frame from the vent assembly frame. Then gently remove the rubber off of the frame and install the new one after you replace the top vent bar seals. Reverse the window removal procedures to reinstall the glass and frame. The top vent bar seals requires a special tool to remove and replace the rivets you get with the replacement seal. You need to replace the top vent bar seal before reinstalling the new vent window rubber. When I replaced my top vent seals, it was fairly easy with my removal/installation tool.
Oct 03, 2008 | 1965 Ford Mustang
1955 Chevy Belair cigarette lighter
first remove the fuse ,and then the wiring ,the cig lighter itself should be in two pieces and threaded together.
Jun 15, 2008 | Chevrolet Chevy Cars & Trucks
Baby Gear Logo
48 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
