Question about Whirlpool MH3184XP Microwave Oven
Whirlpool MH3184XP - No Power
Microwave is about 2 years old and I have checked the fuse on the top right and it seems to be fine. The microwave doesn't turn on at all.
Please help.
  • rbindra Apr 08, 2008
    I fixed it few days ago. It was the small ceramic fuse under the inline fuse. It's covered in a plastic casing. Couldn't find the same fuse anywhere so I ended up replacing it with a 4Amp 250V glass fuse.
  • abeler Sep 11, 2008
    misplaced the other fuse, not the fuse in the plastic case. can you tell me the numbers on the ceramic fuse?
  • Whirlpool Master
  • 9,098 Answers
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 08, 2008
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
THE MICROWAVE WAS OFF WHEN WE GOT UP..WAS FINE LAST NIGHT, NOW NO POWER, LIGHT...NOTHING
first check the power to the outlet.
plug something else (that works) into that outlet to see if it has power.
Jan 24, 2010 | Whirlpool MH3184XP Microwave Oven
Why did my maytag microwave oven power go out completely?
1 your inline fuse blew
2your magnetron t-stat poped
3 bad voltage from outlet
test the outlet with a lamp, if that works it can only be the other two
open the door, take the screww off the control panel
and the vent cover, two screws on top
behind the control and vent you will see the mag t-stat, it should read continuity, and the inline fuse should be right above it a small glass tube fuse like a car
Oct 16, 2009 | Whirlpool MH3184XP Microwave Oven
Nothing working - just quit. Power source ok.
There are 3 fuses in that microwave. I had a similar issue. The one that I had to replace was the little ceramic fuse that is in line after the big fuse which is connected to the main line.
I couldn't find the ceramic fuse but I replaced it was a glass one about a year ago and it has been working since then. The fuse if located on the right front panel.
Dec 29, 2008 | Whirlpool MH3184XP Microwave Oven
Humming sound when off
I also have the same microwave model and with the same problem. It is not quite 2 years old. I have a service call scheduled but did e-mail customer service at Whirlpool to inform them of this. Sounds like it could be defective model and a fire hazard. You should also inform them of yours.
May 15, 2008 | Whirlpool MH3184XP Microwave Oven
Whirlpool microwavewave hood comination mh3184xp
My Whirlpool MH3184xps is shooting a spark when in use with the rack. When the rack is removed the oven works fine. I am guessing that some of the coating on the rack has cracked and peeled and is exposing some aluminum. Has anyone else had this problem?
Feb 04, 2008 | Whirlpool MH3184XP Microwave Oven
Whirlpool MH3184XP-B 2 Black- Will not start, no power, no display
Downstream of the main 20 amp breaker in the upper right hand corner, is a miniture 4 amp fuse in an inline fuseholder. I replaced this and so far, so good
Aug 21, 2007 | Whirlpool MH3184XP Microwave Oven
New Microwave just went out no power
I had the same problem and fixed it with the help of others in this forum. There's a 250V 4A slow-blow fuse in a holder in one of the wires running from the main circuit breaker.  Just behind the upper end of the control panel.  Replacing said fuse got me running again.
Jun 25, 2007 | Whirlpool MH3184XP Microwave Oven
Whirlpool MH3184XP Microwave Oven Logo
282 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
