Just purchased a wifi printer for wireless printing but the cd on installed the version for usb connection. How can I get te software for the wireless connection. This is very frustrating I thought everything I needed was in the box and yet you placed the wrong CD in my packaging.
    Problem Solver:
  • 12 Answers
Most network printers DON'T require a driver to print via the network, all you have to do is to select it from the printers list when you are sending the print job.
Posted on Apr 03, 2008
How to install a printer on laptop?
If you don't have the original installation disc, look at the brand and version of your printer. Go to the main website for the manufacturer and search for the version of your printer. There should be a download available. Download this to your laptop. Use a USB cable or the cable that comes with the printer and plug it into your computer and the back of the printer. After you've done this, run the installation software on your laptop and follow the instructions. Unplug when the installation is complete, or if you have wifi and the printer is compatible, follow the instructions to also connect it for wireless printing.
Oct 31, 2014 | Office Equipment & Supplies
Can't print wirelessly from HP C4750
Original CD must to do this activities: un install the drivers, re install once again,select connectivity as wifi ..if your wire less router/wifi unabled.. If any difficulty in wire less connectivity go to hp web site down load the pdf file read care fully, do as specified.
Feb 01, 2012 | HP PhotoSmart Office Equipment & Supplies
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
I bought my daughter an HP photosmart D110 Series printer for xmas. I set it up here at home using wireless, not USB, and it worked great. Now when she gets to her apartment which also has wireless, we...
start new,
use the D110 full setup instructions from scratch.
install the software from HP.
then on some printers, like mine, the USB way works or wifi
if you set it up to wifi , usb is dead.
and the reverse.
so must be reset , per the manual to get it the way you want.
it is a very complex device, this all in one e-printer
https://support.hp.com/us-en/product/HP-Photosmart-e-All-in-One-Printer-series---D110/4023244
wifi, is complex.
first the user must know the routers settings to make it connect.
but some times you have no access to that router, due to owners
are ISP or landlord.
to use wifi , i must force my router to use a fixed IP (reserved)
or will not connect , reliably, the manual covers this too.
use the HP install package,
rule 2:
NOTE: If the printer is connected with a USB or Ethernet cable, the printer cannot connect wirelessly.
click does not maintain wireless....., seen here.
it tells you to run the hp print and scan doctor there.
Aug 21, 2017 | HP Computers & Internet
Issue: I have a Canon Pixma iP6220D inkjet printer and it will not connect to my computer wirelessly (my computer does not support Bluetooth). Query 1: What type of wireless technology does the printer...
1) This particular printer is available in versions that connect via Bluetooth or via Infra Red. There does not appear to be a Wifi version. 2) To get it to work via WiFi, you'll need PC with Wifi and 3) a Wifi print server like this
Amazon com TP LINK TL WPS510U 150Mbps Wireless Print Server USB 2 0...
Dec 30, 2017 | Canon PIXMA iP6220D InkJet Photo Printer
I want to install the a Lexmark x6575 printer to my computer network by wireless but do not have the installation CD. I have the printer installed on the main computer using a usb cable.
If you haven't configured the printer for wireless connection yet, I suggest you configure it on the main computer first since it's already connected to it. You will have a solid green LED light on on the Wifi indicator of the printer once wireless connection is established. Then download and install the printer software in the other computer. Click on this link for the software: http://bit.ly/bOeC3E . Click on the Microsoft or Macintosh dropdown found below the page to choose the version of your computer's operating system. Then download and install the software. Follow the instructions on the software. Hope this helps. If you need more assistance, leave it as a comment and I'll get back to it. Thanks.
Jul 10, 2010 | Lexmark X6575 All-In-One InkJet Printer
Wireless router is working fine to connect to the
Did you install anything new on the computer you are working on? I suggest you to check the version of your printer driver software according to the driver CD you had and reinstall the compatible version of the driver on your computer with a USB cable connected after totally remove the drivers and settings for that printer on your computer now.
Jul 05, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
HOW DO I USE A WIRELESS PRINTER WITH NO ROUTER. I WANT TO PRINT FROM TWO COMPUTERS, THAT BOTH USE DIAL UP INTERNET
You can attach the printer directly through USB cable to your computer and print, or you can connect the printer and your computer to the same wireless network and then print using the wireless and your connection.
Internet is not necessary, only a communication path needs to be established. For this whether its your neighbor's wifi network, your own wifi network, a usb cable connection between your pc and printer etc printing will be accomplished.
Dec 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
7410xi Software installed but list of printers does not show it
i really cant pin point what you did or did not do...if u follow this HP link http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=391202&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20» you can order the cd rom w software free of charge for the all n one............you will have to uninstall the version you have on the pc...once u get the cd-rom...intstall it....then connect the all n one to pc,,,,,hope this is helpful...feel free to rate
Jun 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Printing through wireless
hi,
if you had the printer before using the USB cable. then you changed it to wireless, try the ff:
1. re-insert the CD the came with the box, the cd that you used to install the printer Software to your computer.
2. after inserting the cd, it will give you option "add a device".
3. click on that to install the printer driver for WIRELESS.
note: the reason why you cant print, is mainly because the printer driver you have is still for USB connection. so inorder for you to be able to print, you need to install a printer DRIVER for wireless... That should WORK..
adonscott
HP TECH
Jun 23, 2008 | HP Officejet 5610 All-In-One InkJet...
130 people viewed this question
jasbo
jasbo
