Mitsubishi Tv model VS-6021CA
The picture is not good dark and clowdy what is wrong? Who can fix it or where can I get the Parts.
  • kswannx3 Apr 03, 2008
    Mitsubishi 60" in Oak cabinet with pocket doors. TV is blurry and dark . who can fix it for me or where can I get parts.
  • 8,617 Answers
Sonds like the Crts need the coolant changed. I would also recomend polishing the mirror and crt lenses dont use windex just a damp soft cloth for the mirror and lenses then dry. If that doesnt help you may need replacement crts thats expensive new. But if you need them I have a line on lots of mitsubishi projection CRTs as well as other brands.
Posted on Apr 03, 2008
SOURCE:
Mitsubishi VS-55609 distorted Picture Flickers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
May 14, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Good Luck, big IRISH.
Apr 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Mar 17, 2008 | Televison & Video
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi vs-50605
does not sound like convergence have had a few with bad capacitors. any good at soldering
Oct 23, 2007 | Mitsubishi VS-50605 50" Rear Projection...
MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Oct 01, 2007 | Mitsubishi VS-4543 45" TV
Screen goes dark
I thught I answered this one but if you disconnet the sensor it should brighten up the picture If it dosent then its part of the brightness curcuit and must be replace. As I remeber thewre are severall models that you could simply disconnect. Or there should be an auto brightness feature in the main menu picture ajustment to simply disable or shut it off. Good luck
Apr 22, 2006 | Mitsubishi The Big Easy TV
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Ekse
