Question about Microwave Ovens
Microwave/ventahood, everything works but will not heat
  • hansonsports Dec 15, 2008
    everything appears to be working (lights, sounds, turntable) but no heat is produced. like it's on power level zero.
  • 109 Answers
Must replace magnetron, high voltage transformer, and capacitor.
Posted on Apr 03, 2008
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
I have a microwave that is not working, I started it and a loud pop and smell happened. Everything is still working, the lights, the motor, the clock, the ventahood, but doesn't cook anymore.
Hello & Welcome to FixYa
The loud pop sound is caused when either it is a bad fuse or the high voltage capacitor itself has gone bad and needs replacement. As everything is working fine so the problem seems to be either with the door switch or the high voltage capacitor that is bad. Please check the door switch if that appears to be fine then to replace the high voltage capacitor you'll have to take it apart completely. Please get back to me if you have any other questions.
Kevin
Dec 22, 2010 | Kenmore 63792 Microwave Oven
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My Maytag microwave stopped heating. Everything
Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Let me know how this works out for you.
Benjamin
May 24, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Microwave doesn't heat up. Everything else works.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
retyet
Apr 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our whirlpool microwave does not heat. Everything
Hi!if your microwave does not heat, it only means that the magnetron is not working, try to look for busted fuse. or check the capacitor for leak, the hi voltage diode sometimes malfunction, and if all of the above mentioned are all ok maybe your magnetron is defective.
Sep 15, 2009 | Whirlpool GH4155XP Microwave Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Frigidaire over the range microwave oven has stopped heating...you set the timer and it acts like it is coming on (light and timer works, but no heating happening). the ventahood and light still...
The high voltage power supply for the magnetron, or the magnetron, or the output drive from the logic uPC board may have failed. The service tech is able to test these areas by taking readings to determine where the fault is.
Jerry G.
Apr 19, 2008 | Microwave Ovens
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Dec 30, 2007 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
156 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
