Question about IBM ThinkPad R32 2658 Notebook
IBM R32 1.8GHz Pentium 4 laptop - won't start up, hardware issue?
I've had issues with this for a while, most of the time when I start this laptop up it just beeps at me but every so often it will try and boot up and fail. I keep getting different errors coming up but I can't seem to replicate any of them (i.e. it's a different one each time). The screen is fine and so is the battery but I can't be 100% sure on anything else. The interal clock is still pretty much accurate and the memory check on attempted start up seems to be fine.
I'm not much of a hardware expert but I assume this is much worse than a simple software issue. My guess is that the hard drive has corrupted somehow but I don't pretend to REALLY know what I'm doing here.
The closest I've got to it actually starting up properly since it just randomly stopped working one day was it getting past the XP loading screen to a black screen with the mouse icon on it, the mouse was responsive in this case.
I can only try to boot from the hrad drive at present as my cd/dvdrw drive has a tendency not to work - the computer recognises it on start up but somehow the drivers are screwed - this has been a long tern problem (unlike the rest of it) and it has only worked like twice since I got it.
These are some of the errors I've got, I don't really know what any of them mean but I thought it may help someone who knows what they're talking about:
IRQL_NOT_LESS_OR_EQUAL
***STOP:0x0000000A (0x00000016, 0x00000002, 0x00000000, 0x804E4A7A)
***STOP:0x000000C5 (0x00IE0140, 0x00000002, 0x00000000, 0x8054B02D)
***STOP:0x0000008E (0xCC000005, 0x8054B539, 0xF8959030, 0x00000000)
***STOP:0x00000024 (0x001902FE, 0xF8979658, 0xF8979354, 0xF837060E)
***Ntfs.sys - Address F837060E base at F82F2000, DateStamp 45cc56a7
ERROR
Resource conflict - Allocation error static node #02
TRAP0000000D ===================General Protection Fault===============
tr=0028 cr0=00000011 cr2=00000000 cr3=00000000
gdt limit=03FF base=00017000 idt limit =07FF base=00017400
cs :eip=0008 :00401431 ss: esp= 0010: 00061FF4 errcode=1010
flags=00010002 NoCy NoZr IntDis Down TrapDis
eax=000489D4 ebx=00404CB1 ecx=00001618 edx=534D0040 ds=0010 es=0010
edj-0047164F esi=00051D68 ebp:00001522 cr0=00000011 fs=0030 gs=0000
TRAP C0000005 =================== EXCEPTION =======================
tr=FFFF cr0=00000000 cr2=00039000 cr3=00000060
gdt limit=03FF base=0003F000 idt limit =0003F400
cs :eip=0002 :00000000 ss: esp= 0030: 00000018 errcode=0000
flags=00000000 NoCy NoZr IntDis Down TrapDis
eax=00000000 ebx=00000000 ecx=0000000C edx=FDFFEF01 ds=0000 es=0000
edj=00000000 esi=00060AEC ebp:00060AD4 cr0=00000000 fs=0010 gs=0010
    President:
  • 2,351 Answers
Hi PopRocks, your system errors show up as memory problems to windows errors & everything inbetween. If your notebook is in warranty, let the pro's fix it. If your notbook is out of warranty the best you can do is use the restore CD & format the drive in your system & fresh install windows. Load your CD or restore CD in to your CDROM drive. Your notebook should show the screen (to run from CD press any key...), (Press any key). Your restore CD / Windows should start to load. Follow the on screen instructions. If your notebook fails to load the cdrom press the F8 key every 2 seconds at start up. Choose your cdrom drive by moving the up & down arrow keys to highlite the cdrom & press enter.
Got my fingers crossed!
Luck....
Mike
Posted on Apr 03, 2008
    Sergeant:
    Champion:
  • 277 Answers
Try to replace your memory ram... then format your hard disk....
3 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: windows crash
These are operating system errors. Start by doing a check disc from the bios or set up. The check disc is a hard drive test, if anything fails then you have a hard drive crash and you will need to replace the hard drive. If it passes, then you will need to run a repair on the operating system using your recovery or operating system disc. If you have any hang ups or issues during or after the repair then you will need to completely reload a fresh copy of the operating system.
Posted on Jul 17, 2008
issken
  • 1472 Answers
SOURCE: irql error code 0x0000000a
stuart607
This stop code, "0x0000000A irql_not_less_or_equal" normally refers to a driver problem. So this is one of the few times where the files that the BSOD lists actually is important. Next I would try to boot the computer into safemode and reinstall/drivers related to that file to see if this make a difference.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Sep 03, 2010
Can you install windows xp on a ibm 380ed laptop
You need to make sure your laptop meet the minimum hardware requirements for windows XP . (see below)
I believe your system has a Pentium MMX 166 MHZ processor which will not be able to run XP properly.
But that's not all, You also need to make sure IBM Lenovo provides drivers for all the hardware on your 380ED, which I don't believe it does.
Minimum hardware requirements
  • Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended)
  • At least 64 megabytes (MB) of RAM (128 MB is recommended)
  • At least 1.5 gigabytes (GB) of available space on the hard disk
  • CD-ROM or DVD-ROM drive
  • Keyboard and a Microsoft Mouse or some other compatible pointing device
  • Video adapter and monitor with Super VGA (800 x 600) or higher resolution
  • Sound card
  • Speakers or headphones
Mar 21, 2013 | IBM ThinkPad 380ED
I have an HP G42 the laptop won't boot or start
HP laptops are well known for motherboard issues, and will usually involve a replacement board, at this point have it checked before a decision is made.
Sep 26, 2012 | Computers & Internet
I have a IBM Lenovo r500 laptop and I am having trouble loading windows 7 on it. I have updated the bios but it has worked since then. Now I am having error messages trying to reinstall it on a clean...
Yes! it could be, is the window 7 a upgrade disc? the reason I ask it will detect the previous version and install, but if the hard drive has been completely formatted it won't install on empty hardware. If that is not the issue go into bios and reset to factory default it might make the difference.
Apr 09, 2012 | Lenovo IBM ThinkPad (2647X800C) PC...
Dead laptop
1.Turn computer off
2. Remove the battery, charger and all accesories connected.
3. Press power button for 1 minute
4. Connect the power adapter only.
5. Turn on the computer.
If not turning on and not even boot to lenovo screen then posible issue with the hardware. call the manufacturer if you are still within warranty they can fix that for free.
Mar 28, 2010 | IBM ThinkPad T30 2366 Notebook
IBM X60 laptop won't start
It really does sound like a hardware problem, perhaps a motherboard/processor/memory issue. If there is no beeping but just humming that is just the fan and drives kicking up.
I would recommend you take it into a repair shop and have them diagnose the issue.
Mar 20, 2010 | IBM ThinkPad X60 Tablet PC
No sound from my IBM Laptop
Hi, I suggest you to uninstall the sound driver you ve got from control panel, add/remove programs. Then download the uptodate driver from IBM support page: http://www-307.ibm.com/pc/support/site.wss/MIGR-42358.html Reinstall it, should work, if not then you might consider to have an hardware issue, in this case I suggest you to contact the IBM support if still under warranty to get a replacement, hardware failure are covered by warranty terms. Thanks and have a nice day J-
Mar 01, 2010 | IBM ThinkPad T30 2366 Notebook
Upgrading cpu in IBM T30 laptop
1. You must have a processor compatible with motherboard, an Intel Pentium 4M 2.2GHz P/N 91P7209.
2. Download and read pages 81 to 86 and above from the Hardware Maintenance Manual:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-42308
3. Pay close attention to reinstall the fan assembly and apply thermal compound if necessary.
4. Re-assemble all the parts again by following the steps in reverse order of the manual.
NOTE: For future reference, your laptop will change to a 2366-FBx, M6x or 2367-FBx model depending on case.
Mar 26, 2009 | IBM ThinkPad T30 2366 Notebook
My keyboard is not working well
Sounds more like your laptops keyboard needs to be replaced
Nov 25, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
IBM ThinkPad T20, Intel Pentium III 700MHz Upgrade to Pentium 4?
Max CPU for IBM T20, 21, 22 is Pentium III FCPGA2 1000MHz (1GHz). Max memory is 512MB (2 x 256MB PC100/100MHz). Max hard disc is 250GB ATA. Newest BIOS is from April 2004 at the homepage Lenovo.
Nov 06, 2008 | IBM ThinkPad T20 2647 Notebook
Need i driver
your solutioni s here
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-42808
Jul 31, 2008 | IBM Netvista Intel Pentium 4 2.4GHz /...
IBM ThinkPad R32 2658 Notebook Logo
1,236 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
