I'm being denied root access to files on MY EeePC.
    Scholar:
  • 67 Answers
Maybe some details about what you are describing would help.
Posted on Apr 03, 2008
SOURCE:
Permission reset
Login with Administrator account on Windows (Root account on Linux) connect the WD passport, access the files / change the permissions.
Nov 14, 2013 | Western Digital Computers & Internet
Warning: mysqli::mysqli(): (HY000/1045): Access denied for user 'root'@'localhost' (using password: YES)
Open up the PHP Config File Config.php (File name can vary) where the MySQL DB connection details are entered.
Change the machine source name, user name and password as per the current system config.
If still not fixing, go to the PHP line causing the issue and echo the connection details, and see if correct values are there.
Mar 04, 2013 | Computers & Internet
I receive the error 'Network Initialization Failed: Permission Denied' when trying to launch Magicard ID software
Hi There,
This error happens when the user does not have read / write access to a file called PDOXUSRS.NET. Earlier versions of Magicard ID (before V3.02) stored this file on the root of the C: drive. If running on Windows Vista, the file cannot be accessed. The last version released (V3.05) in 2008 will run on Vista (32 bit only). If you are running V3.05 already, and still see this error, search for 'PDOXUSRS.NET'. It is probably in 'C:\Program Files\Magicard-ID\data'. Check the permissions on the file you must have read / write access to it. Try logging on as local admin. ensure any users who run Magicard ID have read / write permissions to this file. Magicard ID V3.05 can be found here;
http://www.magicardonline.net
NOTE! You will need to enter your printer's serial number in the QuickSearch box.
Hope this helps,
MC.
Sep 22, 2011 | Magicard Pro ID Badging Software Printer
Cannot connect [email protected] error 1045
This is an access denied error. If you have specified a root password during install, you must supply it when you connect, e.g.:
mysql -p
will prompt you for the password.
Aug 23, 2011 | Sun MySQL
I just bought a 650 gb transend. i was not able to copy files, give me access denied error. so i decided to quick format it and still the same problem. what do i do. thanks.
Hi, welcome to FixYa.
Do you copy your files using administrator account or others? If you don't copy it using administrator account, sometimes there's a policy with deny users to copy files in the root of the drive. Instead, try to make a new folder first, and then copy your files into the new folder.
Mar 11, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
When i try to install a critical update it was denied access by 7 zip. even after uninstalling 7 zip and installing winzip i still get the same response when trying to install updates 7 zip access denied....
Install Winrar, Here is the link
http://www.rarlab.com/rar/wrar391.exe
if you double click the file,the files will be extracted in the temp folder,so after installing winrar,right click on the file and select extract here. and try to install the update now,
Sometime when you extract files and it contains Malware or Trojan,Anti-Virus which support real time scan just block the files and the access denied message is displayed.
Scan the extracted files before installing so that you know it's Virus free.
Sometimes,even if you have administrator right,sometimes due to malware infection, you are denied access to some system hidden giles like folder under Local settings.
Dec 30, 2009 | Compaq Computers & Internet
I removed the password in phpmyadmin as i was using root/root Now nothing is working. I am using mamp Access denied for user 'root'@'localhost' (using password: YES
this might be what you are looking forr http://rudyegenias.wordpress.com/2006/09/15/enabling-phpmyadmin-once-you-change-permission-or-privileges-on-mysql-database/
May 12, 2009 | Sun MySQL
My 320GB External hard drive is showing access denied when I click on it.
the file you need is called takeownership you have to google for it as it's in one of the forums the file is in the form of a zip file and when extracted you select the takeownership and install a little code into your reg and when you select a folder right mouse button on it and select takeownership this willl get rid of access denied garbage and give you full control over the folder and you do the same on any hard drive.
hope this will solve problems of access denied
Nov 02, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
MYSQL Access denied
Hi Buddy,
Try this option....
mysql -u root -p
mysql will then ask you for the password give the proper password.
For changing mysql root password
mysqladmin -u root -p password <<newpwd>>
then mysql ask you to give password this is the old password and now the new password for the root will be newankush.
Sep 10, 2008 | Sun MySQL
Open Questions:
BITDEFENDER customer support phone +$&{[email protected]*1O69} NuMbEr USA .Anita This BITDEFENDER USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 BITDEFENDER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the BITDEFENDER USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, BITDEFENDER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BITDEFENDER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BITDEFENDER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BITDEFENDER USA Calling BITDEFENDER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BITDEFENDER USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BITDEFENDER USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BITDEFENDER USA's phone numbers against each other. Contacting BITDEFENDER USA in General While I8OO8O31O69 is BITDEFENDER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BITDEFENDER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BITDEFENDER USA.Anita
Oct 17, 2019 | BitDefender Computers & Internet
Computers & Internet Logo
26 people viewed this question
Ekse
Alun Cox
