Question about Internet K50-00001 Natural Multimedia Keyboard
Laptop spilt cola on keyboard most letters won' work now......help!
  • 818 Answers
You muste use alchol to clean, rember to switch off your pc.
if not work, you must replace it with another.
Sergio
Posted on Apr 03, 2008
Tip
HOw to Clean your keyobard effectively
Keyboard cleaningIf you're trying to clean a laptop keyboard see document CH000780 for additional help and information. All of the below information applies to standard desktop computer keyboards.
Why? Dirt, dust and hair can build up causing the keyboard to not function properly.
Procedure: Many people clean the keyboard by turning it upside down and shaking. A more effective method is to use compressed air. Compressed air is pressurized air contained in a can with a very long nozzle. Simply aim the air between the keys and blow away all of the dust and debris that has gathered there. A vacuum cleaner can also be used, but make sure the keyboard doesn't have loose "pop off" keys that could possibly be sucked up by the vacuum.
Why? If the keyboard has anything spilt into it (ie: pop, cola, Pepsi, Coke, beer, wine, coffee, milk, etc.), not taking the proper steps can cause the keyboard to be destroyed.
Procedure: Below are a few recommendations to help prevent a keyboard from becoming bad once a substance has been spilt within it.
If anything is spilt onto the keyboard turn the computer off immediately. Once the computer is turned off, quickly flip the keyboard over helping to prevent the substance from penetrating circuits. While the keyboard is upside down, shake the keyboard over a surface you do not mind getting wet or that can be cleaned up later. While still upside down, use a cloth to help clean out what can be reached. After you you have cleaned the keyboard to the best of your ability leave the keyboard upside down for at least one night allowing it to dry.
If a keyboard does not work after trying it again later it is recommended that it be replaced. If the keyboard works but some of the keys are sticky or cannot be pressed in you can attempt to do additional cleaning in attempt to resolve the issue. Unfortunately many times when any sticky substance such as a non-diet pop is spilt directly onto the keyboard it's usually a loss unless you plan on spending dozens of hours attempting to clean each key.
Why? A keyboard that is used by multiple people, such as students or different employees, may need to be disinfected to help the spread of germs.
Procedure: Turn off the computer. Spray a disinfectant onto a cloth or damp a cloth with alcohol and rub each of the keys on the keyboard. As mentioned in our general cleaning tips, never spray any type of liquid onto the keyboard.
Additional Information: Keyboard Page
on Feb 01, 2010 | Computers & Internet
Gateway NV59hu series laptop keys stop
have you spilt something onto the keyboard at all?
Sep 27, 2013 | Gateway Nv57h57u Laptop
SPILT DRINK ON A LAPTOP
Replace the keyboard with a used one from ebay?
May 08, 2012 | Compaq Presario Computers & Internet
My daughter spilt a liquid on her netbook and now the letter are all jumbled
Check on the following website. It will tell you everything you need to know:
http://www.ehow.com/how_5003235_clean-spilt-drink-laptop-keyboard.html
Good luck :)
Mar 12, 2011 | Computers & Internet
W,h,f,k,,l,and backspac letters are not working on my toshiba laptop
Have you spilt coca cola on the keyboard? if so it can corrode contacts.
If not try reseating the ribon cable, if that doesn't work it's a new keyboard. try ebay, price around £10
Jul 01, 2010 | Toshiba Satellite A40-S161 Notebook
I Spilt wine on keyboard. now some keys are writing wrong thing. Mostly numbers and letter o. Eg 9o 65 87 87 9o
I advise you to purchase a new Keyboard and not have any liquids in the danger close area.
Danger Close - If spilt, it will damage the keyboard.
Apr 22, 2010 | Computers & Internet
Cannot type certain letters
Verify that the key is not working in more than one application. It is possible that some keys may not be used in all programs. This generally always applies to the Function keys F1 through F12. If not all keys are working in all programs and you have Windows, attempt to boot the computer to a MS-DOS prompt or Safe Mode and test the keyboard in DOS.
If it appears that a substance has been spilt into the computer.
If any type of liquid has been spilt within the keyboard you can attempt to clean it . however, because of the dramatic decrease of cost with computer keyboards, it is recommended that you simply replace the keyboard to help prevent frustration and possibility of failure again in the future.
Thanks,
CF
Jun 25, 2009 | Sony VAIO VGC-LS20E Notebook
Letters 't,s,d, f" in the key board are not working
I've seen this problem when the keyboard has had liquid spilt into it, Coca-Cola is the worst. I've been able to take some toshiba keyboards apart but it can be fiddly, the circuitry is on 2 transparent flexible circuit boards, with an extra layer between with holes in, when you press a key the top and bottom layers touch through the hole- making the connection. If you can get the keyboard out/apart it might be possible to separate the layers and clean the flexible boards with spit ( yes, spit can break down drink spills and not harm the circuit) but this will invalidate the warranty.. New keyboard required!
Mar 22, 2009 | Toshiba Satellite A100-S8111TD Notebook
Spilt water
You can probably just get a new keyboard for it. Yu can find one cheap and easy by going to ebay and typing in keyboard for your particular laptop model. Or you can find one by going to your computer manufacturer's site. But Ebay would be cheaper. Keyboards on laptops are relatively simple to replace/ install. You could probably do it yourself and save yourself some money. But if you don't have time to, or just don't think you could do it successfully, and you are wanting to pay someone to do it, then the price ranges from repairer to repairer; but still, it should not cost you no more that $100.00 to $150.00, if that much. It could even be cheaper than that; i am just guessing. If we knew each other, I would replace it for free for you, as long as you bought the keyboard for it. But still, you could probably do it on your own. Hope this helps.
Sep 13, 2008 | Dell Inspiron 1300 Notebook
Computers & Internet Logo
51 people viewed this question
Tejodhar Atreya...
Tejodhar Atreya...
vojvodabudva
