What keys do I press to determine how may pages have been used on the printer to date?
    Problem Solver:
  • 14 Answers
It would great if you could tell me the make and model, but I can share these ideas.
Most inkjet printers will print out some sort of configuration page if you hold down the online button while plugging in the power. Some of them you can try just holding down the online button for 8 seconds or so. However a page counter is printer model specific and may not be available on all printers.
Let me know your printer model and I hope this helps =)
Posted on Apr 03, 2008
HP Calibration Error
    For HP Officejet 6600 / 6700 printer models which suffer a calibration error, more than likely either the PRINTHEAD has connectivity issues (i.e. remove, clean all contact points, and reinstall), compatible/clone ink cartridge chips are causing the issue, the PRINTHEAD is approaching end of life, or not all ink nozzles are firing and therefore the printer is unable to calibration. Perform the following diagnostic checks to help make a determination:
    Tap 41 PRINTHEAD Health Diagnostics (NOTE: applies to touchscreen 6600/6700/8600/8700 printer models only):
      1.Press 'Return' button (lower left side) four (4) times until 'Support' menu is displayed.
      2.At 'Support' Menu, using the arrow key, navigate to the 'Service Menu', press Ok.
      3.Use arrow keys to advance to the 'Special Reports' Menu. Select OK.
      4.Use arrow keys to advance to the 'print mech button tap' menu. Select Ok.
      5.'code = 0' will be displayed. Use arrows keys to change value to '41' (i.e. press and hold right arrow key).
      6.When 'Code = 41', select 'OK'. The diagnostic test pattern will print.
      7.Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced. Re-seat PRINTHEAD and/or clean rear electrical contacts and repeat 'Tap 41' test to verify connectivity is not the issue.
      Nozzle test (use to determine if all ink cartridge nozzles/printhead is firing all colors properly)
      Press return arrow 4 times
      2.Press support menu
      3.Press right arrow 5 times to print diagnostic menu and press ok
      4.At nozzle test press ok
      Self test/printer status (use to print internal printer settings)
      3.Press right hand arrow 7 times to reports menu and press ok
      4.At self test report press ok
      Extended self test (use to evaluate color performance and obtain total page count)
      4.Press right hand arrow 1 time to extended self-test and press ok
      Print Quality Diagnostic Page (use to determine if printing alignment is correct)
      4.Press right hand arrow 2 times to Print Quality diagnostic report and press ok
      Print head recovery (runs 'intensive' printhead service cleaning routines, i.e. for a clogged printhead)
        1.Press home key twice
        2.Then return key
        3.Then home key twice
        4.Then return key
        5.Then home key twice...............this will gain access to the Engineering Menu
        6.Press the 'service menu'
        7.Press right arrow 4 times to 'service test' and press ok
        8.Press right arrow:
        a.16 times to 'print head rec level 1' (basic recovery)
        b.17 times to 'print head rec level 2' (medium recovery)
        c.18 times to 'print head rec level 3' (thorough recovery)....suggested for severe streaking
        9.Press 'ok' to activate either of the 3 selections above.
        Semi full reset (can be used to help address intermittent or incorrect printer behavior issues)
          1.Press return arrow 4 times
          3.Press right hand arrow 2 times to Resets menu and press ok
          4.Press right hand arrow 2 times to semi full reset and press ok (Note: this will return printer to factory default condition; regional setup will be required following this action)
          For more information on inkjet printer recovery tips, or solutions for a different printer model, please visit http://www.inkjet411.com
          -Thank you
Nov 22, 2013 | HP OfficeJet Office Equipment & Supplies
Download file now send rfu upgrade on usb dev port
Determine the current firmware version 1. Press Menu . 2. Press the down arrow to highlight INFORMATION, and then press OK. 3. Press the down arrow to highlight PRINT CONFIGURATION, and then press OK to print. The firmware datecode is listed on the Configuration page in the section called Device Information. The firmware datecode has this format: YYYYMMDD XX.***.X. The first string of numbers is the date, where YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20061125 represents November 25, 2006. Download new firmware from the HP Web site To find the most recent firmware upgrade for the product, go to www.hp.com/go/ ljp4010series_software or www.hp.com/go/ljp4510series_software. This page provides instructions for downloading the new firmware version.
Aug 05, 2011 | HP LaserJet P4015N Printer
Have Brother MFC-7840W Printer/Fax How do you set the fax to print off confirmation reports
Hi there!
For you to setup the confirmation here's what you can do:
-Press Menu/set 2,4,1 -Press the Up or Down arrow key and select ON you can select On+Image to get a confirmation with the image of the document that u fax. -Press Menu/set to confirm -Press Stop/exit
To print the confirmation page for your last transaction just press Reports and press the up or down arrow key to select Transmission
Hope this helps! Thanks!
Jun 03, 2011 | Brother MFC 7840W Printer
How do I change the time on my CopyStar CS-1820
Setting the Time Zone
1 Access Time Zone.
If you are unsure how to use this route map refer to Accessing Menu Items on
page 3-3.
2 Press arrow keys to select the time zone that you are in.
3 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
4 Press right Select. The message display returns to the basic screen.
NOTE: Periodically check the time that is shown in the message display and adjust
as necessary to match the current time.
1 Access Year/Time.
page 3-3.
2 To set the date, for each field press arrow keys as many times as necessary to
display the correct value then press arrow keys to move to the next field.
3 When the date is correct, press Enter. The time setting screen
(hour:minute:second) is displayed.
4 To set the time, for each field press arrow keys as many times as necessary to
5 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
6 Press right Select. The message display returns to the basic screen.
Mar 17, 2011 | Copystar CS-1820 Copier
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Jan 26, 2011 | Konica Minolta Minolta FAX3900 Digital...
HOW DO I CHANGE THE DATE & TIME , HP Officejet 6210 All in one
Hi
you can change it by pressing menu
and with arrows get to setting
there you will find date and time
and if you want to refill it easy check here how
Jan 17, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How do I change to the correct date and time on the HP Offfice Jet all-in-one J5780 printer?
Press on the Setup button on printer front panel
Use arrow key till you find TOOLS - Press OK
User arrow key till you find Set Date and Time - Press OK
This way you can setup date and time on your printer.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 14, 2011 | HP Officejet 6310 All-In-One InkJet...
How do I change the date from "Jan 20 00" to the proper date?
To change te date on the OfficeJet J4580 us the following steps.
1. press the setup button (that looks like a wrench).
2. press the right arrow key until you find Basic Setting then press OK.
3. In the Basic setting menu press the right arrow key until you find Date and Time then press OK.
4. Enter the date with the keypad (DD-MM-YY) then press OK.
5. Enter the time with the keypad (HH-MM), use the right arrow key to change between AM or PM then press OK.
These simple steps should help adjust your time settings
Jun 16, 2010 | HP OfficeJet J4580 All-In-One Laser...
I need to change the date on fax confirmation pages to the current date on a Canon ImageRunner 1023iF.
1)Press the Additional Funktion button.
2)Press the arrowkeys untill 6 TIMER SETTINGS is displayed Press the OK KEY
3)Confirm that DATE TIME SETTING is displayed and press then the OK key
4)Change the date and time
Aug 19, 2009 | Canon imageRUNNER 1023iF Black and White...
Number of pages my printer has printed
You need to print a self diagnostic page. On that page will be listed the number of pages printed from trays and accessories.
To print the Self-Test Diagnostic Page
• Control panel: Press Setup, select Print Report, select Self-Test Report, and
then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print Self-test
Diagnostic Page.
• HP Printer Utility (Mac OS): Click Device Information from the Information and
Support panel, and then click Print Configuration Page.
Thanks and please take a moment to rate this as fixya.
Jul 06, 2008 | HP Officejet Pro L7680 All-In-One Printer
238 people viewed this question
