Question about Gateway GT4022 PC Desktop
TASKBAR PROBLEM MY ICONS ARE LINED UP VERTICALLY INSTEAD OF HORIZONTAL
    Novelist:
  • 125 Answers
*Right click the taskbar and make sure the "Lock the Taskbar" option is NOT ticked
click and hold a blank space of the taskbar and move the cursor to where you would like it to be sitting so if you would like it to run across the bottom of the screen move the cursor while still holding down to the bottom of the screen, this should make it look more like what it should :)
Thanks!
Posted on Apr 03, 2008
How do I fix red vertical line?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 22, 2015 | LG Televison & Video
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Horizontal line going through the screen of my tv
    the vertical IC of your tv might cause the problem you need to replace that..replace also the capacitors near the ic...resolder the high voltage section and the vertical section..tnx and good luck!
    Jun 14, 2010 | Televison & Video
    The task bar has to be brought to normal position. the task bar is in vertical postion and has to be brought to horizontal position at the bottom.
    the taskbar can be easily relocated by dragging it using the mouse. be sure to select a vacant area of the taskbar to drag. Also, right click the taskbar to make sure it is not "lock".
    Mar 29, 2010 | Computers & Internet
    How do you set convergence
    What is your Make and Model number?
    I can not found the language bar in my windows vista
    Language bar is in control panel. First switch to control panel to classic way then there is option for language and region.
    hop this help
    Sep 10, 2009 | Computers & Internet
    Just a straight line instead of a picture
    A straight horizontal line across the screen means you have no vertical deflection. Could be as minor as a bad solder joint, a failed capacitor, or the vertical deflection IC is bad. Or shorted diode, burnt resistor....
    Jul 14, 2009 | Televison & Video
    Windows XP taskbar has "relocated itself"
    Right-click the taskbar and ensure it's not locked..
    Then just click on the taskbar and drag it to the bottom of the screen..
    But i didn't understood the iconzied windows thing.. omg
    PS: Please rate this solution
    Mar 11, 2009 | IBM Lenovo ThinkPad T60
    Monitor is vertical display instead of horizontal display
    Hi...there! Kazz,
    Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
    Oct 10, 2008 | ViewSonic VA902 19" LCD Monitor
    Gateway GT4022 PC Desktop Logo
    130 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
