Question about Asrock 775Dual-880 Pro Motherboard
Adding memory and bios upgrading
I have 512g ddr2 533 mhz of an unknown brand and i want to buy one giga. I don´t know if it is preferable to use the dual channel possibility and remain on the same speed with 1.5 Ram or if i should instead go for 1 g of 667. I don´t really know the differences and potentialities of the dual channel but i read in the manual it was obligatory to buy from the same brand and i can´t even tell which brand it is. On the other hand i have this Pc since 2006 and i guess i should make a Bios Upgrade which i also distrust a little bit to do it on my own because someone told me it could be problematic. How hard is it for this motherboard?
  • NicolauChow Apr 11, 2008
    Ok many thanx...I bought two 1 Giga DDr2 667. Now i should put the dual channel thing working but i really don´t know how it´s done because the Bios is not recognizing the first slot Ram. Nevertheless the program SIW is but the computer is not running as fast as it should. How do i upgrade the Bios is this a diificult thing Sir?
  • 13,433 Answers
Hey man, I checked the asrock website
Support DDR-II 667/533/400,
If your going to keep the 533mhz memory in your pc, then I recommend you get another 533mhz, becouse if you get a 667mhz the 667 will run as 533mhz becouse the 533mhz memory is slowing it down.
If you need more assistance let me know, I'm here to help
Posted on Apr 06, 2008
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
Athlon processor upgrade assistance:
Go to this link:
http://us.msi.com/?func=searchresult&keywords=ms-7025
Select the model motherboard you have and click on the CPU support link, it will show you a list of CPU's that are supported. You have a socket 939 board and AMD CPU's are now AM2, AM2+ and AM3 socket, which are 940 pin. It may be difficult to find a new CPU for your motherboard that is new since they have not been made in awhile.
Feb 09, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
Memory upgrade, download upgrade to run 400
According to the specs of this motherboard, it only supports 333, 266 and 200 MHz DDR SDRAM. It does not support 400 MHz DDR SDRAM.
This motherboard has only 2 memory slots, each can accommodate a 1 GB memory module. Higher capacity memory modules are not supported by this motherboard.
No BIOS upgrade is available to provide support for 400 MHz DDR SDRAM memory modules.
Jun 04, 2009 | Intel D845GVSR Motherboard
Dear Sir I want to upgrade my hard disk to SATA 320 GB or SATA 250 GB. But my Motherboard is Intel Corporation D845GVSR and Bios Version is VA84510A.86A.0030.0402160229 System Bus Speed is 533 MHz Sys
No, don't use a convertor. Please buy a SATA PCI addon card.
like this http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=pci+sata&x=0&y=0
the above card will do alot better job than a converter, if you don't have sata and you don't have room for the card then its best that you buy IDE drive which 250GB or more.
thanks and good luck.
Ekse
May 13, 2009 | Intel D845GVSR Motherboard
How do I determine what kind of memory that I need?
Go to Crucial.com and install their configuration utility through your browser. They will tell you what you have and all the combinations you can do to max out your system. Look at the specs of the RAM and you can get it from Crucial or some other vendor.
Dec 30, 2008 | Computers & Internet
Upgrading processor
Do not know much about mac but can you change settings on M/board by using jumpers to upgrade bus speed etc or in BIOS
Aug 13, 2008 | Giga Designs G4, 1.3 GHz (5-1213c)
Large hard drive
Yes it will. Mostly it is the operating system that will allow the drive to be see at its full size. Suggest you use Win XP home with at least SP1 but Win XP Pro with SP2 is faster & very stable. Also suggest you set the drive up with the Mfg's disk utilites. Bootable floppy or bootable CD. If using plain XP home you can still install the OS & than download a free trial of Partition magic which will allow you to combine any smaller partitions to get you up to you 250GB size. (only if you have a problem though.
Feb 26, 2008 | Intel Motherboard
TOTAL UPGRADE
>Can I upgrade the processor as well? Pentium 3 is compatible and what is the maximum MHz? Maximum CPU for GA-6BXE is Celeron-1400 (Tualatin core, with PowerLeap Adapter: http://www.powerleap.ca/Products/PL-370T.htm ...and patched bios by BIOS Patcher: http://forum.rom.by/topic5071.html&highlight=6BXE (last official BIOS don`t support Tualatin CPU-s) >A bigger HD will be compatible? With last F3a-version or patched bios - upto 128Gb. >The BIOS can aslo be upgraded? For max CPU / HDD - must be upgraded.
Sep 23, 2006 | Gigabyte Slot 1 GA-6BXE Motherboard
Asrock 775Dual-880 Pro Motherboard Logo
137 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
