Question about Whirlpool Calypso GVW9959K Top Load Washer
Sears CAlypso my washer is leaking water from it, can I fix this myself?
  • 3 more comments
  • deanz3 Apr 03, 2008
    Thanks, I was having trouble figuring out how to open it up, so i will try that and let you know if I got it.
  • deanz3 Apr 04, 2008
    I'm having trouble getting into the washer and following your instructions. Maybe I gave the wrong model
    It's a Kenmore Elite with Calypso Wash motion
    Trying to get in so I can see where the leak is but I have no idea how to open it up
    Thank you
    There is no emblem/mediallion there, there is nothing there it is all flat panel with no emblems anywhere on the machine
  • amtoc Aug 29, 2008
    Does anyone knnow how to get the top of machine open so I can check hoses for leak?
  • handyun May 11, 2010
    Greetings, same probelm, leaking calypso washer, took off front, back and bottom. The leak is not the pump, nor a visable reject hose or an inlet hose. Tub? Everytime I start the washer, without any thing in it, the tub goes askew and locks up. The agitator also seems lower?
When the tub is too full, or if you are washing something that does not absorb water (like a shower curtain), the calypso action can splash water over and out of the tub. Sometimes this happens for me even when the tub is not that full.
Posted on Jul 10, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
Dont see why not, first t hing to do is find out where its leaking from, the fromt panel will need to come off to watch for leak in order to remove that , pop off the medalion on fron lip of the main top assy. ther should be a screw behind the emblem remove the screrw and the top will slide foward and then tio back. a few screws across the top of front panel will drop that panel down adn from ther you ll gain acces to watch unit work adn see where water is coming from
Posted on Apr 03, 2008
  • Ron Coons
    Ron Coons Apr 04, 2008
    is ther not a calypso medallion on the very front leading edge of the main lid assy, would sorta be where your belt buckle would hit if standing in front of.if so pry it off
    there should be a screw behind the emblem..
    remove the screrw and the top will slide foward and then tip back.
    a few screws across the top of front panel will drop that panel down adn from ther you ll gain acces to watch unit work and see where water is coming from
Install new pump
Google my posting on www.bobvila.com for checking/replacing the Calypso pump. One of their best known engineering defects. They should have put a filter in front of it! It clogs and stops working, burning up the pump motor usually. I've replaced mine myself twice. Sears replaced it two times before the warranty ran out. Hope this helps.
Tom
Apr 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Water leak at the bottom?
you may have hose leak, or you may need to replace the water pump.. also check the hoses from the water supply lines. water may be running down behind the hoses
Oct 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Machine - Thanks you for your Response Posting!
the class action lawsuit comprised of people who still owned their units and needed repair. what whirlpool would do is send a repair technician out on their own, they would get a list of parts for the washer and replace them when the parts came in. i own a calypso and my u joint went out and whirlpool repaired it free of charge over a 400.00 due bill to them. was just good that it never came out of my pocket. however ive since learned how to fix my unit. bt i havent had any issues with mine since the u joint and pump were replaced. i replaced the pump myself and other tuff rquired a special tool. im not sure if they are giving compensation on the washer but its worth a call to whirlpool.
Nov 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer Stops/Starts when filling with water
Looks like part 8571359 the control electronics is out and guess what? Can only get through Sears and Whirlpool. This is why you cant get an error code, it isnt working well enough to choke one out. You know this is hard to say but a Oasis has its issues but at least it is still on market. I would if hubby is handy to find a used machine and pull the part. It is a chance but cheaper than 500 bucks to have a tech come out and fix.
Oct 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Sears Kenmore Calypso Washer
Usually "FL" means one of two problems, both with the drain system. The good news is that both are relatively easy to fix yourself. "LD" can also be fixed by doing the following as well.
First, get the washer somewhere outside, in a garage or basement where you can afford to have large amounts of water spill out onto the ground. It may be easier to dismantle the inside of the basin and get as much of the water shop-vac'd out before you move it. Once it's outside, open up the back panel, and on the bottom left you will see a large black hose with clips on either end. Take the clip that attaches the hose to the bottom of the tub off and all the left over water will spill out. Turn it on it's face now, take the bottom panel off, and remove each of the clips on the hoses (drain hose to) and make sure nothing is blocking any of the lines. If it is, then remove it and this MIGHT fix your problem.
The other option (if the previous doesn't work) is to replace your pump motor, because odds are it has gone bad. The Calypso washers are notorious for having drain issues, and there was even a class action lawsuit a few years back that would have likely allowed you to get the washer fixed for free. If you do need to get a new drain pump motor, they go for anywhere between $80-100 and are a breeze to switch out. Hope this helps.
May 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Extra Heavy Duty Calypso Top Load Washing Machine
I had this problem and did not have the time to fix it myself so I called Sears. The "tech" looked at his laptop, called his "supervisor" a couple of times and told my wife that both control boards needed replaced at a cost of over $500. The manuals, with testing procedures for the inclined, are on the inside, front cover.
The CE error is a communications failure and on mine it required replacement of the AVS board. I bought the part at a local supply house and replaced it myself for about $175.
Jan 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
141 people viewed this question
Dan Webster
Dan Webster
Sal De
