Question about Minolta EP4000/5000 CS/PRO Copier
Minolta ep4000 cs pro imaging unit
I need to repl the iu in our copier. the service guy says they aren't making parts anymore. but, the machine is in excellent shape and works great. i'm sure someone somewhere has one or some company reconditions them, but i'm not having much luck. any ideas?
  • Minolta Expert
  • 1,326 Answers
Ask you service guy if he can or knows how to rebiuld your IU / drum unit. You can still get parts for that copier you probly need a new OPC drum and cleaning blade and a developer change. I belive they should last for 80k copies more or less. Are you getting black lines and bad copy quility? If not you may just have the PM / IU light ON or it is asking for a PM? It is just a counter in the copier that say's it time to replace the PM parts. They may have been replaced , but the counter was not reset. On a final note, this is one model in a long line of the same machines with alot of the same parts. I don't think it is hard to find these parts. You can buy them on line.. Under copier part....
Order the parts your self and save money and have them install them... Good Luck
Posted on Apr 03, 2008
  1. GIVE ME A CALL 619 843-1992
Posted on Sep 24, 2008
Exit tray broken for a Minolta CSPro EP4000
Legacy machine from Minolta now Konica Minolta. Try ebay? Or super glue. Try the web sit below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 18, 2013 | Minolta EP4000/5000 CS/PRO Copier
My minolta ep4000 copy machine print the pages black why?
Clean the optic sisitem componenets,mirrors(4 mirrors),lens,original glass,clean the erase lamp obturation filter(located in OPC drum area,clean the drum charge corona unit(wire,grid).
Mar 09, 2013 | Minolta EP4000/5000 CS/PRO Copier
My photocopy machine minolta ep4000 its up and bottom side of the page are coming black
When was the last time you had a Konica Minolta Tech come out and give it a cleaning and replace parts such as developer, Drum, corona wire xfer and sep wires, cleaning blade. Botton fuser roller mite need to be replaced. A Minolta legacy machine, try the web site below to get a start on the above parts Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Oct 20, 2011 | Minolta EP4000/5000 CS/PRO Copier
Erro c oo copiadora minolta 2030
Check the fuser unit remove it (THE HOT PART) check for broken gears and also check inside once removed, also check the drum assy., check that drum can turn remove image unit, the using thumbs on each end turn the drum clockwise. if the cleaning blade is yellow replace it.
for parts try this site. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
Minolta cs Pro- Works but print black copy?
Please clean the mirror unit,the trasfer and separator coronas,and perform F5 AIDC control.
May 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
Touchscreen and coalator connection
The back light on the display panel has burned out. I'm not sure if the LCD assembly is even still available for this model. Before we completely discontinued servicing this model, we couldn't get them anymore from minolta. The last one I replaced was about six months ago and I had to get the replacement part off a junked machine in the warehouse.
Jul 13, 2009 | Minolta EP4000/5000 CS/PRO Copier
Smudge on the paper
When you say smudges, do you mean toner spot or blobs of toner on you pages? If you get random blobs of toner... You need to take out the drum unit & remove the primary charge unit & remove the drum & vac. out a small little grove that seats right below the developer mag roller... It is most likely filled with toner and is dropping on to you paper as copies are being made. Good Luck
Feb 18, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
Services
what kind of problem are you having, please be as descriptive as possible.
thanx,
mikey
Mar 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
118 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
