I have a LC-37HV6U Aquios LCD TV. I moved it to another room hooked it up correctly and when I power it on the tv "clicks on" then turns off then turns back on then back off and continues in one second intervals but never fully powering up.
    Sergeant:
    Champion:
  • 241 Answers
The internal power supply looks like is overheating and failing causing to blink, you could get someody that's handy with voltimeter and check resistance and continuiti on the power supply board
it has to be done by a experienced person due that you are playing with electricity
Posted on Apr 03, 2008
We moved our tv to anothor room and now all it does is light up the name when turned on. Nothing else will work. Everything is hooked up correctly
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc. Abctay com China Wholesale Wholesale Electronics Gadgets tv parts power...
Oct 16, 2017 | Televison & Video
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Hi I have 2 faulty LCD TV with A1T4l30PN00 power supply. One of the lcd you turn on the tv with remote control and the red light is bliking but will not turn on the TV. I know the power supply is faulty...
TV is often turned off when some parts of the circuits got too hot. You should try to use a room fan to cool the back of the TV and see if it improves by itself before you try to fix the TV. Overheating is often caused by condensation, which also can be dried by a room fan slowly move the air..
Nov 30, 2010 | Televison & Video
How do I reset the secret code for a lcd Sharpe aquios LC-C5277un
Factory Default Reset:
- Unplug the TV and count to 10 slowly.
- Hold down the power button on the TV (not the remote.)
- Plug in the TV while holding power button.
- Count to 10 and release the power button.
- Turn it on and hope for the best.
Sep 24, 2010 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
I have sound but no picture from all my AV inputs on LCD TV. It was working fine then when I switched sources from sky to xbox they stopped working. All connections are fine
Ur LCD inverter board is dead.Replaced this board will get the piccture back.It a long board.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 10, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I accidentally plug in my sharp aquios 110v to 220 v
If your TV is a LC-42D62U like it says on the post, there seems to be plenty of parts at shopjimmy.com
What part does he need to replace?
Feb 13, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aqous lc 37 in tv power no picture,sound
Your control board seem's defective or the inverter board (associated circuits) are bad. This is common in most TFT-LCD Tv's.......
Nov 30, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp aquios 32"
unplug the tv from the power outlet, wait until the light stops flashing then plug it back in. works for me.
the flashing light means that your tv needs to be serviced, if its still under warranty you shouldnt have to pay for this.
-w
Nov 17, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
