Question about Furuno NavNet vx2 1920C GPS Receiver
Navnet 500 Hello, I purchased a boat with the Navnet 500 autopilot installed and I am having a little trouble learning its use. Today I tried to use its Nav mode by setting a waypoint on my Gamin 3012 and following the "Nav" mode instruction. It did not work. Tomorrow I am going to return to the boat and run a "Test" diagnostic as well as try to operate the unit in "Auto" mode> The truth is, that I don't even know if that Garmin unit is connected to the Navnet 500. My boat also has a Furumo chartplotter installed but it appears to have been used only as a radar, as there are no cards plugged into it. Is there some place or someone that is well versed on this unit that can look at my installation and help me with ensuring that it is working properly?
  • 398 Answers
I have been doing some research and I haven’t been able to determine if the Garmin has a compatible output for your Furuno. I can not recommend any service center particularly since I have no idea where you are located, but any good marine shop should be able to help you.
The Furuno uses NMEA Inputs for the GPS, and like I said I haven’t been able to determine if that Garmin uses that as an output. I would suggest that you inspect your installation to determine if there are any cableing between the two units. If no wires connect the two that you can be sure that the units are not communicating.
As far as the chartplotter goes you can buy data cards for them, either on-line or from a good marine supply store.
Posted on May 04, 2008
SOURCE:
Bottom machine signal is slow and weak
Slow, not sure, weak al;lmost for sure it is the tarnsducer.
Buy a new one and hang over side of boat in deep water to test.
John 847-746-0100
Jan 30, 2013 | Furuno DFF1 Digital Network Sounder for...
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
How do i reboot my furuno navnet......recently installed radar and system not recognising teh radar installatio. no count doen on radar page greyed out overlay icons on the screen
Press and hold the "MENU" button during power on. Release "MENU" after boat appears.
Go through the installation wizard. You must select the radar type, "B" is 1834.
May 21, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
How connect the nav net vx2 to autopilot simrad.what output port and colour cable
Get someone from a marine electronics company to do this for you. If you are unsure of the basics of what you need and you attempt to do this while going in blind, you may ruin your nmea ports on your navnet and autopilot. While I understand that you are trying to save $$$ by doing this, there's more to it than just wiring. There are port setups and nmea sentences to enable etc.
Jan 18, 2010 | Furuno NavNet vx2 GP1720C GPS Receiver
Connect Furuno 1732 to st8002 autopilot
It will handle the voltage. as far as the wiring goes, you'll have to decide which port to use. the wire coloring is different. you'll have to send your nmea out data from port 3 white and shield ( Like you said) to the pilot and receive your heading data from the pilot on port 2.
Apr 11, 2009 | Furuno Navnet 1732 GPS Receiver
Need owners manual for furuno navnet vx2 1834c
easy one, download here
http://www.furunousa.com/Products/ManualList.aspx?category=Products+%3a+NavNet+vx2+%3a+Radar+%2f+Chart+Plotters
Feb 22, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
I would like to purchase a full Furano Navnet 3D system with for my 42' sailboat now in production. It does not have hydraulic steering though. Is there a hydraulic linear drive compatible withe Furuno...
No, you will use the appropriate Simrad Drive unit such as an HLD350. It comes in long and short throw and split versions, and dual ram versions. Better to discuss on the phone probably. 847-746-0100 or email [email protected]
Aug 09, 2008 | Furuno NavNet vx2 1920C GPS Receiver
I can not seem to get a simrad ap 20 to recognize the nmea connection from the navnet vx2
you will have to designate which sentences to send to the AP20 from the navnet under port options. also make sure the AP20 is set to read the correct port to accept the information such as gps1 or 2 or nav1 or nav2
Jun 29, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno navnet 1723 C
go into installation mode (hold menu during power on) find radar setup, go to next page, do heading alignment. also tune video, your unit was reset!
Jun 09, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno NavNet  vx2 1920C GPS Receiver Logo
132 people viewed this question
Top Furuno GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Furuno GPS Expert? Answer questions, earn points and help others
