Projection tv has a reddish tint on the screen and appears to look hazy and flushed. Flesh tones have a red/orange hue.
  • Anonymous May 07, 2008
    how do you know if a color gun is bad?
    Sergeant:
    Champion:
  • 241 Answers
First try adjusting the color-tint on the menu if this does not solves the problem you have a failing proyector and has to be replaced
Posted on Apr 03, 2008
The screen has a reddish tint to it. Seems like a color issue and not sure what to replace. The picture works fine but everyone is red. Not sure if there is a bulb to replace or what? Any suggestions? This...
You need a simple color adjustment. (Color Calibration)
You don't need to spend money on this. Try it for yourself.
Your main problem is that your color temperature is set to warm.
You need to change temperature to COOL or 6500K depending, on how it is labeled.
You will see improvement, but there is a little more...
Move "Color" DOWN from it's current position (probably at 50) to somewhere between 30 and 40. (Just a couple of clicks above where the color rapidly washes out.)
At this point there will still be slightly unnatural color to skin tones, but all the artificial "sunburn" and blaring red will be gone.
Last (as far as color goes) move the tint 2 to 4 clicks toward green. This added green tint balances the color so that the flesh tones become completely accurate and realistic.
For even better detail, continue your home calibration here:
http://www.wowvision.tv/main.htm
Jun 13, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
My RCA 61" DLp has lost its red hue.
If its not the color wheel its the Light engine! Call Encompass Parts 1-800-638-3328
Dec 17, 2009 | RCA HD61LPW165 61" Projection HDTV
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
No color hues
Have you tried more than 1 source? If this only happens with 1 source- if you're using component cables (green, blue, red) then make sure there is nothing wrong with it. Another thing that can cause this, is a component (RGB) device being plugged into a composite a/v input (yellow white and red).
If this fails, or if the problem is with all sources, the TV is the problem and probably won't be easy to diagnose or repair yourself.. I'd call the manufacturer if this is the case.
Jun 21, 2009 | Philips 43P8341 43" Rear Projection...
Well i really want to know what level the coular and brightness lvel has to be on a toshiba t.v
You can set these controls to your liking, though a lower brightness setting might increase the life of the screen. First, set the brightness and contrast to a level that is pleasing to the eyes, then adjust the color to look realistic - enough color without being disturbing. If faces area look greenish or purplish, then also adjust the tint (sometimes called Hue) until you get accurate flesh tone. Flesh tone is the best thing to adjust for; when you get good flesh tone, the rest of the picture will look great. ALWAYS make adjustments during a live news broadcast, which tends to have the most accurate balance of brightness, contrast, color level and hue. Note that commercials are all recorded in different studios with different settings, and will usually not look right - it's best to just live with this than to constantly readjust the TV. There are also DVD's available which walk you through proper TV adjustment.
Jan 02, 2009 | Toshiba 36AF41 36" TV
On my Philis 51PW9303/17F projection TV, the colors are weak. Adjusting the color and tint have no effect on the color intensity or hue. I was given this set and it was worked on. THANKS Mike
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 30, 2008 | Philips 51PW9303 51" Rear Projection...
Color is weird.
Component Video Jack was loose.
Dec 14, 2008 | Sony KP-48V45 48" Rear Projection...
Vizio 37" LCD color problem!
is the TV still under warranty. if it is I would call Vizio and request a main board be switch and if it is not under warranty I would call a TV Repair shop and have them put in a Main Board.
Mar 04, 2008 | Televison & Video
Flesh tones and red colors
any hue adjustments usally relly cheap tv u got also hard to get good colers from it the lg one is nice i like samsung and sharp
go throw azll colers cheak dvd cables
Jan 06, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
241 people viewed this question
Top Televison & Video Experts
Electro Med Services...
