Question about SanDisk Sansa m240 MP3 Player
My m250 player won't work when I turn it on.
When I turn my m250 player on the sandisk sign comes up but it won't go to my songs. What do I do?
  • 758 Answers
Try holding the power button down for at least 10 to 15 seconds. That should turn it off. Turn it back on. If this doesn't work, try taking the battery out for a few seconds. If that doesnt work i will recommend that you update the firmware on your device..
To update the firmware follow the link below
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Should you need additional information you can contact sandisk..
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Apr 03, 2008
SOURCE:
My Sansa M250 is only 1 month old and won't recognize Music folders now when I plug it in. My PC does recognize the device but now it only shows Audible, Config and Record. Before it showed playlist,...
reset the device to factory defaults thats it....
check your usb ports are working properly in not i recommend to re instal the usb device drivers also
Jun 27, 2011 | SanDisk Sansa m250 MP3 Player
Sandisk sansa m250 mp3 player problem
try formatting it or updating the firmware
Feb 11, 2010 | SanDisk Sansa m250 MP3 Player
Files not deleted from m250
Try this solution:
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 14, 2009 | SanDisk Sansa m250 MP3 Player
How do you put songs on to a sana M250 mp3 ?
The SanDisk Sansa m200 cooperates well with Windows Media Player 10 and subscription-based applications such as Napster To Go; it works without a hitch via drag and drop in Windows Explorer, even automatically organizing your files.
Sep 08, 2009 | SanDisk Sansa m250 MP3 Player
Communication with PC
It is a lot easier if you have Windows Media Player. It should always work.
Mar 20, 2009 | SanDisk Sansa m250 MP3 Player
I cant delete files from my Sandisk M250 mp3 player
Just called Scan Disk if the device got a setting wrong:
Turn the Scan Disk on:
Go to Setting;
Select USB
Change the selection to Autodetect
Go back to Windows Media player the songs should show up..Worked for me.
May 18, 2008 | SanDisk Sansa m250 MP3 Player
Can't find my songs
The songs are in the wrong format
Nov 20, 2007 | SanDisk Sansa m250 MP3 Player
No files
Hi, A common problem with MP3 players and not only SanDisk. Below is a copy of my reply to postings of similar brand/models or problems - This is a common problem with MP3 players with almost a full memory. Apparently, the firmware gets messed up and eventually losses recognition of its purpose or some of the files it keeps. Sandisk has anticipated this problem and has posted online utilities just for this purpose. They are available at > http://www.sandisk.com/Retail/DriverDown... Hope this be of some help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
Oct 01, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
