How can I re-tune my panasonic plasma HT TV. I have a hd dvd also that were originally tuned together. Last night I swithed to TV (analog) to watch one program (poor reception on SBS). However I am now unable to get HD channels? Please advise.
    Sergeant:
    Champion:
  • 241 Answers
Can i have the tv model please to check it out ?
Posted on Apr 03, 2008
SOURCE:
How to get video from dvd to tv
Use HDMI wire if you have that option than simply tune TV to HDMI 1 or HDMI 2 etc depending which one you connect it to .
OR. analog ( R C A ) cables analog. Output from DVD player to imput tv """ red is right white. Is left sound. Yellow is video pay attention to where you are plugging on TV.video 1 or 2 or 3 Since you will have to go to ( video. Or imput ) on your TV to access the DVD player. Another words your cable box is a TV imput . You're doing is also a TV imput You have to tune it to be able to watch it
Feb 16, 2015 | Universal 40-42 Inch Flat Screen Panel...
Unable to tune my liteon dvd recorder DD-A300 to a panasonic tv
I'm a bit confused about what you are trying to do? DVD recorders don't tune in to TV's anymore. They output the signal to the TV via a connector such as HDMI. To record the recorder will need an aerial feed etc, which can be split using a splitter between what feeds the TV and Recorder.
Dec 20, 2012 | Televison & Video
Tuning
U want to tune in free air tv?,not analoge signal anymore.All digital now,must have a good antena like digital antena,and a digital converter box.Or must have cable or setalite signal.Than can watch without a converter box.
Dec 18, 2009 | Televison & Video
Do I need to tune my tv to watch a dvd? I have connected my dvd player to my tv (I don't have an ariel, I simply want to watch dvds) do I have to tune my tv and if so, how do I do this?
No, the dvd player is totally separate. you will not need to tune your TV, just plug the DVD player in via a scart or an HD socket, and run through your channels till you find which one it is on :)
May 16, 2009 | LG GSA-E10L (8801031212552) DVD±RW Dual...
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
42"HD PLASMA, No sound on Analog input
I think the problem is dry solder joints on the tv. What makes be believe this is you turning it on and off may have been moving the component/s into contact with the board or the act of you turning it off let everything cool down enough to return to their original positions. It now sounds like the contact has broken with the component and the circuit. If you can check for this yourself otherwise find a competant technician. Hope this helps.
Sep 23, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Is it possible to tune Hd or Sd channels on the DMR-E85H. I can only tune in analogue stations
Unfortunately no, it is not possible to tune Hd / Sd channels on the Panasonic DMR-E85H, because it only has an analogue TV tuner.
For Sd, you could insert a 'digibox' between the RF aerial input and the DVD, but you won't be able to get Hd currently unless you subscribe to a cable or satellite provider.
Mar 17, 2008 | Televison & Video
Hitachi 42PD8700 U
switch on the dvd player so it's playing, then do a new master tune. press the dtt/tv button so you are watching the internal freeview system, then press menu, then go to installation, and re-install all channels. the tv will then detect your dvd player in the intial set up/tune mode.
hope this helps..
Oct 17, 2007 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
Ekse
