Kleen maid washer leaking seals
Kleenmaid washer leaking seals and bin brakes gone is it worth fixing and where can i get parts. washer 16 years old
  • roachie12 Apr 04, 2008
    might buy new machine thanks
As an addition to the response by Ian Greenland, you may like to refer to an article in the Fixya 'Tips and How-tos' section which may give additional info as to how to evaluate the issues at hand for repairing the leaking seals, which I would perceive as the major issue.
I would doubt that would find that the brake pads are difficult to replace, and would thus regard them as a secondary issue.
Link:(Fixya:) KleenMaid Washing Machine KAW651 Hub Seal Replacement QuickReview
Posted on Oct 24, 2014
    Sergeant:
  • 351 Answers
Normally i would replace brake pads $44.tub seal $ 160 belt $55 and pulley assy on gearbox $ 65 its not a hard job but if you have never done one it may be trikky.also make sure the gearbox shaft under the agitator isnt wobbling if it is buy a new machine.
Posted on Apr 03, 2008
I have a kleenmaid washing machine its about 30 yrs old and still runs well but it is now leaking oil from under the adjitator how do i fix it.
Sounds like the seal for the transmission is leaking oil through the seal. You will need to remove the tub or turn the machine upside down to remove the transmission and replace the seal. That is if the seal is still made.
Nov 17, 2015 | Washing Machines
Whirlpool duet front lading washer, GHW9150PW4
Could be drum bearings gone Quite a big job hence costly with around 3 hours labour plus parts, some models need half drum as the bearings are loaded in here,leak could be door boot seal at 7 yrs old not sure if worthwhile as its about the end of its working life.Good luck
Apr 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaks from bottom
you can open the front panel of washer and see if water is coming from the pump located to the right very close to the front of the machine. if the leak is coming from there is an easy fix. you may have a loose drain hose. If the leak is coming from the center of the drum, is a bad news, center chaft seal is bad, if this is the case, it's not worth it to deal with it.
Apr 03, 2014 | GE GTWN4250MWS
Drum is leaking in our Frigidaire GLTF1670ASo Washing Machine. Is it worth fixing a 9 year old washer with this problem, I am thinking of buying a new washer. Please advise.
With nine years your machine reached an age that I consider close to end-of-life. Frigidaire / Electrolux boasts 25 years of warranty to some parts, but don't count on it. They'll enforce handling by an authorized service partner, upfront payment of several hundred dollars and eventually refuse refund due to too hard water in your area or they'll blame you of using unsuited detergents, all after two months of processing.
Leaking drums for these machines are quite common as they put together unsuited metals, in this case an aluminum extrusion spider in the back of the inner drum and steel parts elsewhere. Corrosion and leaking is pre-programmed.
Jan 01, 2011 | Frigidaire GLTF1670A Front Load Washer
Loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Mar 05, 2010 | Kenmore 44042 Front Load Washer
Leaking maytag
it could be the pump but there is a seal in the tube where the transmissin goes through the tub that seal has a common problem of leaking but if it 10 years old i would replace the machine
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Leaking Water & Sqeaking
Main seal has gone bad and needs to be replaced. It might be worth it to you unless you are a mechanical person that you either have a company repair this part or replace the washing machine. The part is fairly cheap but the job is somewhat difficult. You can order the part at repairclinic.com
May 27, 2009 | Washing Machines
I have a front loading frigidaire washer gallery 1670 series
I would say yes, its worth keeping. Mine leaked a while ago and I bought a new pump assembly. I think it was about $70. You can remove the two screws on the bottom of the bottom face plate and remove the cover. The pump is on the right side. Look for goo leaking out of the shaft seal. Verify before you buy parts, It could be the rubber boot torn or something similar.
Don't reach inside untill its unplugged.
You can replace the shocks easily too. Lots of parts places online with illustrated parts catalogs.
Jan 19, 2009 | Frigidaire GLTF1670A Front Load Washer
Washer leaking when filling up tub
Unlikely to be pump, sounds more like hose leaking, or drum seal.
Depending upon severity of leak, place a sheet of newspaper under front of m/c, pushing it as far back as you can. switch m/c on for a few secs, then switch off, remove paper and you should be able to judge where leak is.
Tilt m/c back and have a look underneath.
At 12 years old, if it looks major, I think I would replace m/c.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Maytag Dependable Care LAT9206
Maytag legacy series washer leaking
Price is right. Repair time is right for an inexperienced repairman. Worth it ? If you watch what you are doing and not rush then, yes, it's worth it.
Jan 11, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
325 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
