PT-47WX49E My Panasonic TV turned itself off this morning and now it will only come on for about 2 seconds. When it first went out the led turned yellow then shut off. Could you offer any advice to this problem? Thanks, Toddo
  • 934 Answers
Several things could be causing the problem and without some trace testing it would be hard to determine exactly where the fault is... Could be convergence amps Ic7001 and Ic7002 are very common failures in this unit along with one or more 2.2 ohm resistors in the return R70xx check them all to be sure.
Could be vertical circuit - or esr C524 in the feed for the vertical.
Could check R867, R858 & R860 near the regulator circuit. But my first guess in all this would be the convergence amps.
BTW - this is a P7 chassis and uses two STK392-110 Sanyo amps. If bad replace them with STK392-150's or 180's for greater reliability.. And don't buy the chineese knock-offs.
Bill
Posted on Apr 03, 2008
I have a panasonic PT-60lcx64 that wil turn on for about 30 seconds and then turns off by itself. Whats going on?
sensor protecting tv and shuting down, count # of led flashes, if any, possible power board or overheating
May 26, 2010 | Panasonic PT-60LCX64 Television
Panasonic PT-47wx49e
The repair tech is wanting to take alot of your money, you can get the entire deflection baord which has the flyback on it remanufactured for about half of what he wanys to change the flyback. Heres alink leave them a email with your model number they will send you a quote to have your deflection D board rebuilt which carrys a full warranty. heres the link.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Televison & Video
Panasonic PT-47wx49E
does the led indicator blink? If so how many times does it blink?
Sep 04, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Blue ghosting on Panasonic PT-47WX49E
your convergence IVs need to be replaced. Its an easy repair if you can solder. you can get the two ICs you need at the following link. they also provide free installation instructions and free on line tech support while youre doing the repair. You need two ICs they are numbers STK392-110. Let me know if I can be of further assistance. I am one of servicemanuals support techs and board rebuilder.
Apr 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Help please
called h.v. shut down call tv repair shop
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49E will not power on
Thats a power supply module going bad. Dont use it until a person with knowledge on TV see that. Or if you feel you can DIY open the back panel to see if there is a toasted or foreign object near the power supply area. Its located when you follow the main plug going into the back panel of your TV. Look for a dying Fuse too. And watch out for Capacitor that has still current, you may electicuted with that component. That parts its only for qualified servicemen area only.
Aug 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX49E Doesn't work
This is for sure a safety shutdown circuit that is shutting down this TV set. It is a hard call to pinpoint a problem such as this without first doing some troubleshooting on the TV set. You could have a short in the sweep power supply, the horizontal output transistor could be bad, therefore then the flyback is probably bad, or the vertical IC could be bad, there could be a regulator problem in the main power supply that could be bad, and also the convergence IC's can cause this problem. Almost any circuit inside this TV set can be detected and staop the set from starting up. Good Luck
Jun 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX49E Service Manuals
scott iam in need of one too would you PLEASE add me to your list Thanks so much
Apr 11, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
