Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Dust inside tv
Hi, is it advisable to clean dust specks from the inside of one's television? Can you indicate the best procedure to employ? My warranty does not cover cleanings of any sort and I thought if it wasn't technically impossible to do so myself I would use an LCD cleaning kit to perform said wipe down - the dapped spots are annoying when an image has a light background, but is swallowed whole by any kind of texture. I have had the bulb replaced and a new light engine and religiously clean the filter but the dust problem persists (it was a display model and I probably should have cleaned the filter right away, but waited, rather stupidly, around 6 months into the purchase). Is there a way to avoid making this worse and still cleaning or is it necessary to call a tech - and if the latter scenario is recommended what will he or she do to ameliorate the problem (as in - will this cost an arm and an opposable thumb?). Thanks, Garland
    Sergeant:
    Champion:
  • 241 Answers
There is some air cans that you can get on any computer store and try to blow out all the dust, then with a hand vacuum try to absorb it very carefully
Posted on Apr 03, 2008
How do I disassemble a Vizio E3D470VX Smart TV, to clean out the dust inside the Screen
Hi Alonzo,
To clean the dust inside the screen, you will have to disassemble the LCD panel. It is a very risky job and there is every chance of damaging the LCD screen unless you have a real good experience of doing it. If you are not good at doing such jobs, please let some professional do it for you.
Jul 05, 2016 | Vizio Televison & Video
Spot in tv
The spot may be from debris inside the chamber of the TV box. A bug, dust speck, or other material can attach to the inside screen or on a color tube inside of the unit. Do not touch the inside of the Front Screen as it has a special coating and you could damage the screen permanently. Avoid washing with water or sprays that can enter the frame of the screen. Use a cloth with cleaner applied to it and wipe clean, then dry with a soft rag or paper towel.
Mar 17, 2014 | Hitachi 50VS69 50" Projection HDTV
Dust inside lens of Sony Cyber-shot DSC-H55 digital camera
That is more than likely to be dish on the sensor of the camera (or CCD) you can get do it yourself kits but this is tricky as the sensor is inside the camera. Your best bet is to take it to a camera shop who should clean it for about 30 or 40 pounds, and guarantee it for a certain period too. Or you could send it off if there are no local photography shops, search for "CCD cleaning" online. Hope this helps!
Dec 27, 2011 | Cameras
I need the inside of my projection tv cleaned.
The best way to clean out inside is to use an air compressor and blow out all dust, or go to the dollar store and buy cheap paint bushes and bush out the dust, then clean mirror and all 3 top of Tube lenses . Make sure TV is unpluged.
May 31, 2011 | Televison & Video
I have several dust particles on the inside of the lens, betweeen the first and second glass elements of the lens. This causes dark "shadow spots" to appear on wider angle photos. How can I...
Hi there.
Sadly, point-and-shoot cameras are not designed to be disassembled and then reassembled easily. Therefore your best option is to take it to a store that specializes in camera repair.
Mar 01, 2011 | Panasonic Lumix DMC-FX7 Digital Camera
Have a JVC HD-Z886 61inch, there appears to be some black spots behind the screen. Looks like dust, most at top of screen, not a big problem. Is there any way to clean behind the screen? When new the TV...
  • The most severe problem dust can cause in an LCD TV is a short circuit. This occurs when dust enters the television's casing and settles on one or more of the internal circuit boards. Enough dust can cause a short circuit, which will prevent the TV from working at all. In other cases, it will damage picture quality or prevent certain features from working properly.
    Because a short circuit can only occur when enough dust is present inside the TV, this problem happens after the TV has been in use for a number of years, meaning that it will not be covered under the manufacturer's warranty. In many cases of short circuits, repair is expensive, and you are better off buying a new set.
  • Image Quality
  • Dust can also have an effect on an LCD TV's picture quality without entering the LCD's casing. Dust that settles on the surface can distort the picture and decrease its brightness. While it's easy to wipe the dust away, use only a soft cloth and mild cleaning solution to avoid scratching the screen or causing permanent damage with caustic cleansers.
    Dust under the screen can be more difficult to clean. Using compressed air to blow the dust out is the best option, short of disassembling the set to clean the screen from the inside. Keeping the surface of the screen free of dust is usually sufficient to prevent dust from getting under the screen.
  • Control Problems
  • Another effect dust can have on a an LCD TV occurs when it enters the space around buttons, making it difficult to control the television. On certain sets, dust will cause buttons to stick or prevent them from engaging when pressed. Using compressed air to blow the dust out, or resorting to using only the remote control, will solve this problem.
  • Jan 24, 2011 | Televison & Video
    Black spot on pictures - cleaned lenses and inside
    The spots can be in the inside of the lens settings to the CCD/imager.
    If the cleaning of the lens is done well it can be a speck of dust logged in to the screen and having it on the image.
    A careful cleaning in a dust proof set up is required.
    Sep 25, 2010 | Nikon D50 Digital Camera
    Internal dust speck on Canon A720is in same upper right corner
    If dust is in the camera, it must be opened. I suggest not doing this yourself. Lookup a Canon dealer in your region and ask for support.
    Jul 22, 2009 | Canon PowerShot A720 IS Digital Camera
    Streaks on prints
    Lines/streaks at the same location indicate either a speck of dust stuck on the glass or the glass may be scratched.
    S. Mohan
    Aug 19, 2008 | HP Photosmart s20 Film Scanner
    Does dust specks inside lens cause blur in the pictures?
    If you have a SLR camera you can take your lense off and clean it.. I do not reccoment canned air because if you do not use it the right way liquid will come out. At best buy they have cleaning kits, and in their kit they have a little brush that you can squeeze regular air and brush off anything on the lense or around the lense, If you have a SLR camera you might have a built in cleaning option... SLR means Single Lense Reflex and this means your lense can come off/interchangable..
    Jun 12, 2008 | Canon PowerShot G2 Digital Camera
    Mitsubishi WD-52525 52" Rear Projection HDTV Logo
    274 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
