LIGHT SWITCH I BEEN HAVING PROBLEM WITH MY INTERNET I HAVE A WIRELESS ROUTER THAT IS CONNECT TO IT IN ORDER FOR ME TO LOG ON THE HUB IN SWITCH LIGHT WOULD HAVE TO BE ON IF NOT WOULD NOT BE ABLE TO LOG ON CAN YOU TELL ME HOW TO SWITCH ON THE LIGHT SWITCH.
  • Cary Micheau
    Cary Micheau May 11, 2010
    please specify the brand name and model number
    New Friend:
  • 50 Answers
What Model#, Name??
Aloha
Bob
Posted on Apr 24, 2008
Hi I have a RangeMax - and it has always been working fine. Last week I couldn't connect wirelessly, so I reset. Nothing. Now I've tried connecting wired through the hub - still nothing. The power is...
Can you please check the signal strength of the wireless router.
If you can log into the wireless router management page and check for the erros if any inside the logs.
Oct 30, 2010 | NetGear RangeMax WPN824 Router
We can not longer connect to our WS 2000 symbol wireless switch, can it be turned off/on without a problem
You possibly have lost the IP from the router
1. if you do an "ipconfig /all at the command prompt that is bring up a DOS window
a. type the command ipconfig /all
b. then type the command ipconfig /release then ipconfig /renew\
you should be connected again that is if you have not lost the connection with the ISP
( Internet Service Provider)
2. check the status of the main router to see this
a. log into the router using 192.168.0.1
Oct 06, 2010 | Symbol WS2000 Wireless LAN Switch...
I need to ask about my problem. I just bought a D-Link DES-1008D and a D-Link DIR-300 Wireless-G Router my problem is after I attach 7 computers on my switch hub. I only have limited local network...
Make sure you're using a crossover ethernet cable to connect the router to the switch. Also make sure that the router has it's DHCP server up and running.
Nov 03, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Power light is red. Hub is OK. No wireless and Internet connects
Have you tried configuring your wireless settings? If your internet works hard wired, its just the wireless settings that need to be configured. Access the router's setup by going to http://192.168.0.1 and change the wireless channel. Make sure to check the wireless security as well and verify if you are using the correct wireless network key
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Can i use the 2wire 1000 modem only as a HUB or Switch?
The 2wire Modem acts as a router too. Some Models have wireless connections. You can use hubs and switches along with.
Jul 30, 2009 | 2wire Computers & Internet
Lost connection between switch and hub - LED flashes every 5 secs
You say you have the same problem when you connect the cable directly from router to laptop, so it apparently is not a hub problem. That leaves the router and the cable. You're fortunate in having a working system on the other port. Why not try swapping pieces to see which is the failed piece? For example, what if you swap the ports for the cables? If it's a router problem, then the "bad" cable should work when in the other port. What if you swap cables? That would reveal a bad cable. Finally, swapping computers would show a computer configuration problem, such as the connection not being set to automatic.
Jan 23, 2009 | Dynex 5 Port 10/100 Ethernet Switch...
I have a acer aspire 5315. I bought a D Link dir 615 wireless internet router. The problem I am having is that I can connect to the router, but I cannot connect to the internet. What is the problem?
Hi the router has not picked up your IP address.follow this Turn off your wireless router and internet connection and your laptop aswell for 30secs .Then first turn on your internet (if seperate from the router) if not switch on the wireless router/internet hub and wait untill the lights stop flashing then switch on your laptop and that should work.
Dec 15, 2008 | Acer Aspire 5100 Notebook
Switch connectivity
Depending on router brand you may be able to log in and check that wired portion is enabled...look carefully at documentation for instructions. I had a similar problem with a D-Link Router and found the info for enabling wired connection at their website. Another problem I had one time was ( believe it or not ) one of my cats has a **** for chewing on wires !!! It was an easy fix after figuring out the problem. Cat is now at SPCA ( just kidding )
May 07, 2008 | Encore 10/100 FAST ETHERNET 8-PORT SWITCH...
Cnet broadband cnig-914
Can you log into the Hub at the IP http://192.168.1.1/ when it is connected to the computer and the internet connection? Perhaps it is just a configuration issue. http://www.cnetusa.com/support/manuals/CNIG-914D.pdf is the link to the manual to setup your router. Without further information about your network and its configuration I can't give more specific information. If you will please post any specifics about your configuration I can hopefully assist further. Please tell me how many computers there are, how many are directly connected to the router and how many are wirelessly trying to connect. Another suggestion is check your boot up order. Often times you have to unplug everything, then plug in the internet router, give it time to full boot up and have all lights on, then plug in the additional router (in this case I am assuming that it would be the CNet Cnig914), again allowing all the lights to come on, then plug in or turn on any pc that is connected directly to the router, followed by any computer that is wireless. This allows each system to be assigned the IP address and recognize the previous equipment. Once it gets an IP and everything is working you shouldn't have to repeat this process.
Nov 09, 2006 | D-Link DI-704P Router
Open Questions:
Cloud Backup, Data Recovery, Data Backup, Cloud Back up Solutions 'Dataalign These days, not only businesses but individuals increasingly need access to their data on the go without thinking about storage and hardware maintenance costs. Online Cloud backup provides an efficient solution and is swiftly attaining popularity. Before cloud-computing, end users stored their personal data on computer's hard drives and memory cards. Unfortunately, computers and mobile phones require physical proximity to the device to allow access to the stored data and are far more vulnerable to damage and accidental deletion. Individual devices need diligent support and maintenance, and ensuring the security of the data remains a challenge. With, Server Cloud Backup Solution end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software Cloud Backup publishing companies choose to offer Cloud Backup For Small Business web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. An online backup service isn't much capable if the process of restoring your data and getting back to being productive is not simple and quick. DataAlign offers a search tool to find a backed-up file. Also, the ability to replicate an entire folder-tree structure, helps with preventing bigger data losses. Versioning is another capability offered by DataAlign. This allows you to see earlier versions of a file in case you made Online Backup Pricing some undesired edits. This can also be termed as archiving function. You can set the number of versions and days you wish to keep any file and utilize the maximum available storage space. Using the version history, you can view the history of each file stored and undo mistakes, if required. Any accidental deletion of file from the computer and can be restored instantly as deleted files are backed up on the cloud. The moment the data is no longer required, you can setup a data destruction policy.
Apr 25, 2018 | Individual Computers & Internet
Computers & Internet Logo
590 people viewed this question
David Payne
David Payne
