Question about Foxconn 865A01-PE-6EKRS Motherboard
How to connect a power in motherboard?
Hi
in my motherboard there is not a pin to connect the power SW.
how to connect this kind of motherboard?
please help me.
thank you
    President:
  • 2,351 Answers
Hi zarathoustra, still have your manual? Go to page 25.
As shown here.
how to connect a power in motherboard? - 26b4ba3.jpg Little fuzzy.
Need your manual, click this link.
http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000010
Suggest you save the link.
Good Day!
Mike
Posted on Apr 03, 2008
  • Mike Peluso
    Mike Peluso Apr 03, 2008
    Jumper settings
    Genius:
  • 1,027 Answers
If this is the foxconn that is posted this link is for the manual. Page 33of 124
Connector cn-41 it has 9 pins 2+4=PWR LED, 6+8= Pwr Sw, 10=no pin. 1+3=HD LED, 5+7=Reset, 9= not connected.
6ya staff
SOURCE:
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
Dear sir...greetings... i have a ibm fw82801db motherboard which is working fine... the main problem what i am facing is i have a 20 pin front panel jack like FDD jack as unable to connect my front...
Because of the many configuration of motherboard, I can possibly know how to help you with this problem without the keyboard in front of me. The best advice to you is to go back to the manual to find the proper connection of those jumpers.
Feb 26, 2011 | Intel Desktop Board D845HV Motherboard
Hi sir the problem which i am facing is that i unplugged the 4 pins which are these rest sw,power sw, hdd led and + and - now i forgot how to place it back in right sequence so plz help me out thanks.
Hello myasinmalik,
this is a [Picture Diagram] of the {PIN Sequence], in the order of "Connections."
!Warning: "Before disconnecting, or connecting: Cables, Wires, Power Supplies, or Pins!"
"Unplug "All Power Sources" from {'Wall' AC - Power Outlets}."
This can cause "Injury to Persons, and or Damage to Equipment."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 23, 2011 | Mercury P4VM800M7 Motherboard
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
Connecting Power SW ec..
Hi there.
On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | PC Chips M871G Motherboard
Motherboard manual To connect main wires
Usually indications are printed beside proper connection Pins . Find your model number and posta comment to look for your motherboard data sheet on web.
Sep 17, 2008 | Intel Motherboard
EMachines T3256 Desktop
Generaly, the little connectors on the printed side will face the bottom of the case. Also, typically, Black is negative, and white/colour is positive (except on the power sw, it doesn't matter). On the motherboard, where the connectors go, there should be some kind of print saying where to plug them in. (IE, POWER SW, would go into PWR, and HDD LED would go into HDLED and POWER LED would go into PWRLED).
It may look different than this, but generally the same kind of layout, as you can see, it shows the positions, as well as positive and negative.
The fact that the fans are running indicates that your power Sw is connected properly.. Make sure that you didn't accidently pull out/loosen anothe connection to the motherboard/harddrive.
Sep 05, 2008 | E-Machines Athlon XP 2200+ (rb-t2200-c67)
Can't connect front panel Power SW cable
On your board in the corner at bottom, you find pins for front panel Power Switch Cable, over there in small characters PWR SW is written, you can put your Power SW Wire there
Jan 02, 2008 | Intel D845HV (735858149143) Motherboard
Foxconn 865A01-PE-6EKRS Motherboard Logo
1,610 people viewed this question
Top Foxconn Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
