Question about Sony KP-57WS510 57" Rear Projection HDTV
Red shadows and mild distortion
Today when I turned on my TV, I now have red ghost images and red lines that streak across the screen. This is true no matter what the source of the signal. At the bottom of the screen any lettering that scrolls across the screen actually shows up also as red letters which curve up instead of travel side to side. I assume I need a service call. What's wrong?
  • RajSony May 18, 2008
    I turned on my SONY KP-57WS510 TV this morning and there is red ghost following all over the images. Please if some one knows how to get this fixed. Any kind of help will be highly appreciated.
  • Spiderman3 Jun 02, 2008
    I have a same problem. Manual adgustment also failed. Some one said that it is time for replace 2 convergence ICs. Is that gonna fix the problem?
Posted on Jun 03, 2008
  • 4 Answers
Hi, relasmith did you ever fix your tv kp-57ws510
thank you
Posted on Apr 09, 2008
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Color ghosting or shadows
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Convergence Problem RCA HD52W59
you need to test all cables then make shure it is not your tv.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Red line convergence problem on KP-57WS510
Yes replacing the ic's should solve it. It worth a try if you want to spend the money
Jun 02, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Feb 14, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Sony KP-57WS510 57" Rear Projection HDTV Logo
173 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
