Question about Dryers
The top of the dryer gets very hot, but inside the clothes are not drying. I have to dry the clothes 2 or3 times.regular size load. When I use cotton setting, it's worse. Water gathers along the inside of the door, and actually drips on the floor.
  • 110 Answers
Okay this is a easy problem, your dryer is clogged, check your vent hose and make sure it is not kinked, also check your vent duct from wall to outside...What is happening is your heat and lint is not going outside but it is going back into your dryer, causing your dryer to get extremely hot....
your dryer is suffocating
marclavoris/Whites Appliance Repair
Posted on Apr 03, 2008
Frigidaire gleq442ces0
I had this same problem 3 weeks ago, and here is what I found.
The dryer was so clogged with lint it could not dry the clothes. I had to take the whole machine apart and clean all the lint out. I found the felt around the drum was worn out, and that was allowing the lint to go everywhere it shouldn't. With the felt replaced and the lint gone, it worked well.
Be blessed.
Jun 23, 2013 | Dryers
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Dryer not drying
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.(clear the lint trap as well)
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Dec 11, 2009 | Kenmore 73952 Gas Dryer
Dryer gets hot, but not drying clothes
Check the following areas thoroughly to address this issue.
1. Venting
2. Thermostat
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
4. Moisture Sensor
Most units will have a moisture or dryness sensor as well that will fail. inspect the sensor for faults. replace if necessary.
Sep 05, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer sometimes works other times doesn't
Check and make sure there is not lint build-up in the venting hose leading to outside. This will cause longer drying times and can be a fire hazard. Also, if you use the Aluminum venting hose instead of the white plastic it can cut up to 30 min. off your drying time. It is a lot safer then the white venting hose which can also be a fire hazard. Make sure all the lint is cleaned out from the inside of the dryer where the venting hose is connected. It could be a clog there. This sounds more like the problem since the clothes are actually drying but it could be a partially burnt out heating element. Good Luck.
Dec 16, 2007 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
180 people viewed this question
Top Dryers Experts
