Question about Nintendo DS Lite Console
Nintendo Ds lite not working needs to be repaired
When I switch on my DS Lite the two screens remain blank. Was told that it is a common problem with DS Lite and that I have a faulty lower main board. Xo yo deal with such a repair and if yes what is the cost of labour and parts
  • 3 more comments
  • pudu Apr 03, 2008
    My Nintendo DS Lite does not switch on. I flip the power switch on the right but the green light does not light up and the screens remain blank. Ca someone help?
  • Anonymous Jun 14, 2008
    We are having the same problem with my son's DS...the green light comes on but both screens remain blank. I bought a new one for him, but was wanting to get the other repaired to give to one of his friends. Any suggestions?
  • Jonathan Loak Dec 26, 2008
    I have the exact same problem, appeared suddenly, not after a knock or being dropped, just happened. Mine charges ok orange LED comes on and such. and the battery gives a good reading, and checked F1 and F2 fuses and those are fine, i'll have a check for loose connections.
  • belle1774 Dec 28, 2008
    My neighbour has a similiar problem, her daughters DS lite ( ONLY 3 months old ) doesn't turn on, nor does it charge. As the power cord is inserted the charge light briefly illuminates, but as i said, BRIEFLY. Any solutions?
  • smithsrus Jan 24, 2009
    power light is green but screens not on ?
Sounds like you both have a lose connection on the circuit board, so easily done, even if one cable is slightly misaligned the ds will not turn on, do they charge o.k?? if so it is a faulty connection
Posted on Apr 03, 2008
My ds lite power gooes off as soon as you turn it on
The bottom screen flashes an then the green light goes off new top screen is needed very common on ds lite i repair them for a living an can sort yours for about 18 quid
Simon
Dsdoc
Nov 26, 2011 | Nintendo DS Lite Console
Nintendo ds lite screens blank, although green power light on
possible that the flex holding the lcd is broken.
Feb 16, 2010 | Nintendo DS Lite
Green lite on both screen blank nintendo ds lite
sorry to say you need a new logic board, you could try to change the fuses but that probably wouldnt work.
Jan 16, 2010 | Nintendo DS Lite Console
Ds LITE WILL NOT STAY ON EVEN THOUGH FULLY CHARGED!
Well the reason behind that is if you left it plugged on all night it will take some battery life
Jul 20, 2009 | Nintendo DS Lite Console
Power is on but my nintendo ds lite stays blank (black screen) both screens
Did your DS get a small bang?
The problem you are having is the L2 fuse located immediately below the on/off switch when you open up the DS (lower screen).
If you give the DS a very mild rattle you will here it rattling around loose inside the DS (in most cases). A lot of the time this same fuse can be soldered back into place to fix the problem all you need is a soldering iron and a triwing screwdriver (eBay).
If it is this fuse and you cant find it, you should bring it back to Nintendo for repair or your local PC repair shop should be able to help.
Jun 14, 2009 | Nintendo DS Lite Console
I punched the nintendo ds lite touch screen and the system won't turn on even when the battery is full it sometimes turns on and the screen appears the nintendo ds and the caution but after that the screen...
lol your ds is broken since you punched the main system or whatever which is located like right below the touch screen i think I'M NOT A TECH GEEK U NO i suggest u get it fixed or buy a new ds
Mar 30, 2009 | Nintendo DS Lite Console
Blank screens/no sound on ds lite
This definatley sounds faulty. Try turning it on again without any games inside. If it turns on okay without a game then it may just be that game you had inserted into it, if this is the case then try a different game to determine whether it is the game or not. If the screen still remains blank then take the DS back to the store where you purchased it and they should replace it free for another one.
Dec 15, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Problem
That sounds like your DS lite have a lose circuit part rolling inside so thats why it cant turn on.
You need to open the console, recover the lose part from the inside and resolder it in its place (usually near the power switch, marked as L2). That should fix the problem, if not then you might have blown fuses, lose screens ribbon cables or broken LCD screens. All of these repairs are discussed in other questions here.
Regards
Nov 08, 2008 | Nintendo DS Lite Console
Nintendo no power
I had bridged the F1 and F2 fuses and then replaced the top screen and seemed to fix everything
if you need more info or are looking for someone to repair I also do console repairs and have fix quite a few nintendo ds lite systems.
let me know and ill help you out.
either info or a fix
Aug 24, 2008 | Nintendo DS Lite Console
Non-working top screen
If you see lines on either screen of your Nintendo DS Lite during game play, then it is likely one or more of the components that create the image on the screen are damaged. This can occur if there has been an impact -- such as being dropped or hit -- to the Nintendo DS Lite's screens. Phone 1-800-255-3700 to discuss available repair options and they will be grateful to assist you at any time of need.Important Note: If you are seeing lines on the screen that slowly fade away after turning off the system, this is normal.
Oct 28, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
396 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
