Question about Dryers
Dryer my dryer will not work at all now it a hovver
  • shellboo99 Jun 25, 2008
    I dried a load.. and a few days later went to use the dryer again and it would not come on.
  • 110 Answers
Check to make sure you have the right amount of voltage, check your breaker first.
Posted on Apr 03, 2008
6ya staff
SOURCE:
How to download simple calculator for toshiba PC? can you gimme the link?
There is a calculator within Windows. Click the Windows key, hovver on programmes and open accessories. Choose calculator.
Feb 03, 2014 | Toshiba Computers & Internet
Can't log out of windows 8
If you hovver your mouse pointer on the right side of the desktop about 1/4 of the way up, a menu should appear.
Dec 28, 2013 | Packard Bell Easy One II 3136 Notebook
DYSON DC07 ORIGIN BRUSH ROLLERS WONT ROLL WHEN HOVVERING BURNING SMELL AND SMOKE FROM BOTTOM OF HOVER ROLLERS WILL MOVE BY HAND ANY IDEAS, THERES NO BLOCKAGES.
Hi There,
Ok so I have made a few videos about what to check when you have issues like this.
THere are 3 possible causes.
1. THe bearings in the brush roller are worn so even though you can turn it by hand the belt cannot.
2. The clutch belts are too stretched and are slipping causing them to heat up and start to melt.
3. The roller on the clutch has melted as a result of the heat from teh belt.
From experience the most likely cause is that the bearings are worn and likely the belts are stretched. I will link a video from our youtube channel watch the one I link and then do a search within the channel for DC07 and you will see the other videos.
You should be able to get away with just replacing the bearings or the belts. I will say that if you have got to the point where you are having issues with the front end I would encourage you to replace the DC07 filters too normally they have a similar lifespan.
Jun 13, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Im knew to facebook , and i have a yellow triangle with an exclamation mark inside it??? i dont know what e-mail its onna bout and when ever i hovver my mouse over it , it says : " Sorry , Chat is...
Ususally this means that Facebook themselves have disabled the chat option to do some work - once it has finished they will re-enable the Chat and the triangle with the question mark will disappear - The 'chat' function allows you to chat with those of your friends who are also live on facebook at the same time, rather like messenger or Skype.
Hope this helps.
Aug 02, 2011 | Facebook Social Network
Fridge freezer not getting cold and freezing
This issue is frequently seen when the valve that diverts refrigerant between the top compartment and lower compartment is stuck closed.
It is advisable to turn the whole unit off to prevent any further damage within and contacting a domestic appliances service engineer in your area as soon as you can to have the valve replaced and the unit regassed (If neccessary 50/50 if it does or not)
Please also be aware that this can be an expensive repair and in many cases it is more cost effective to replace the unit than get it repaired.
If you elect to replace be sure to buy one with a lengthy warranty as had this unit have been under warranty Hovver will have paid for the repair.
Feb 28, 2011 | Hoover HCA390K Bottom Freezer Refrigerator
Hi I have a Hovver 5050ED Dryer, I have replaced the belt but the problem is still happening. When you load the dryer push the door button in & press start the drum doesn't turn the motor hums but if...
It sounds like your motor is faulty and cannot handle the load resistance.
You need to have the motor changed or have a Whirlpool engineer come and take a look
Jan 27, 2011 | Whirlpool LER4634J Electric Dryer
Hovver HD washing machine - Fault Code E 16 keeps coming up Problem with water - wont stop filling even when programme began>
you are in luck....I searched the internet over for this one, hope it helps. E16: Very high water level - turn off water supply, and have inlet valve checked or replaced, or water level sensor checked/replaced.
Also, here is a link for you to save for future errors. Please remember to rate this solution high for me.
http://www.letsfixit.co.uk/html/fault_codes.html
Jan 25, 2011 | Hoover Washing Machines
Hoover Freemotion Pets 200W has lost most of it's suction!
if you take out the dirt cup at the top there should be a half moon orange that releases. inside of this half moon is a washable filter. rinse with warm water and let it dry completly before putting back into the machine. this should restore your suction. hope this helps.
Jul 31, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Changing the belt
If this is a Savvy, then take out the screws for the bottom plate, then remove the screws that hold the top on, turn the vac over, and remove the Hovver emblem, there is a screw there, then the top cover comes off and you can replace the cogged belt.
May 31, 2008 | Hoover U8185-900 Upright Vacuum
Hoover steam vac jr. F5411
First take the guard off the nozzle and remove the nozzle being careful to not let the spring fly. Now pull off the little white tip of the nozzle which less than 1 inch long. Run a needle or fine wire through the main hole running parallel to the hose and make sure you can see it at the head of the nozzel end. It is best to also blow on it to make sure any dirt particles are gone. Even a speck of dust in your solution part of the tank can easily clog it. In 90% of these vacs, that solves the problem and I have repaired at least 50 of them in the past 4 years.
If that doesn't solve it then try this:
Take the impeller on the bottom out by flipping the tank part over, and clean it. Make sure it spins well.
These Hovver Jr Steam Vacs are long lasting and very effective in cleaning spills and stains. Our janitorial company has many of them and in 5 years only one of about 60 has finally been shelved for parts only. I have replaced a few nozzles and several tank latches plus filters, hoses, and the brush and capp on the end of the hose. An additional chore that is made easy with this is defrosting a freezer!
Nov 21, 2007 | Hoover F5411 SteamVac Jr. Canister Vacuum
Dryers Logo
42 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
