Back to:
Tags:
Printers
Generic problem for all Printers
ERROR MESSAGE : 0502
posted by gtiedith on Apr 02, 2008
After changing the ink cartridges on my Lexmark ExecJet IIc printer/scanner/copier/fax machine, and put the top down, it came up with this error message. When I put the top back up, the printer head with the ink cartidges is stuck, does not move from the left hand side of the machine as you face it.
Can you help?
Edith van Dommelen
Tel/Fax: 61 8 93006103 Mob: 61 8 413887318
Email: gtiedith@zeta.org.au (preferred method of contact)
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 03, 2008
Not Rated (0)
map9966
Rank:Guru Guru
Rating: 89%, 1301 votes
Hi gtiedith, sometimes the carridge just gets stuck. Leave the lid open. Power off the printer. Clean the carridge metal rod with a tissue. (Just a little wipe should do it. Than grab the carridge & slide it to the right about 2 inches. Close the lid & power on the printer. It should be just fine. Print a test page if you want to.
Have a good day!
Mike
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ERROR MESSAGE : 0502:
I don't want to Accept this solution
Can you Help with these Printers problems?
Printers
Refund on Hp Printer that promised $20...
Printers
orange light indicates paperjam, but it is not visible...
HP PSC 2175 All-In-One InkJet Printer
I was printing a project in color. After printing three...
Printers
Using a Mac OS X 10.4  with HP Photosmart C3180 First...
Samsung SCX-4216F All-In-One Laser Printer
When copying printing is faded down left hand side of...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
