Question about Vacuums
Bissell quicksteamer plus-model 1950c j01339 bearings burnt out at the water pump at the base of the shaft of the armature. How do you dissasembile to replace the bearings of the centrifugal propeller between the two propellers ?
  • morrfran Jul 24, 2008
    I have the same problem.
    Take off the end cover for the pump, four screws. Take the motor out of it's housing. Remove the plastic cover that covers the brushes. Next remove the brushes. Now look under the brushes and you will find two screws. Remove the screws and the rotor may be removed. Now you have easy access to the bearing.
    I need a new bearing. Where do you find them?
    Frank
    framorrow@gmail.com
Water comes out to fast. What is the problem??
Posted on Aug 11, 2008
    Problem Solver:
  • 12 Answers
I don't know about this particular model, but it usually helps to look for your vacuum's service manual online or in a bookstore. good luck.
Posted on Apr 03, 2008
What's your problem? how to replace nozzel for bissell quicksteamer
The User Guide for your Bissell 1770 QuickSteamer can be found here:
http://canada.bissell.com/images/UserGuides/1970-2080_English.pdf
Available replacement parts may be ordered online here:
http://canada.bissell.com/Products/p/1770+quicksteamer/ak/replacementparts/Product.aspx
Was not sure if you meant you were having difficulty with actually removing and replacing the nozzle? Please reply if you need further asistance
Oct 27, 2011 | Bissell 1770 Quicksteamer II Upright...
I have a Bissell Quicksteamer plus model # 1950 and when I plug it in it begins to heat the water then trips the circuit. Can this issue be corrected?
Have you cleaned the tanks recently? If not do it.
Remove water from the solution tank and collection tank.
Keep the tanks open and allow to dry in sunlight.
If you can, remove the solution tank and see whether there are any leakage signs where the tube connects to the solution tank. If there are, use an adhesive that can withstand heat and stops the leak.
You can also contact Bissell consumer service on 1-800-237-7691.
Aug 07, 2011 | Bissell 1960-3 QuickSteamer Plus Upright...
NO,LOOKING FOR MODEL#2070 FOR BISSELL PRO STEAMCLEANER, INSTRUCTION MANUAL
Model 2070 is listed as the Quicksteamer™ PowerBrush on the Bissell website. The User Guide for the 2070, although labelled for the 2050 is here:
http://canada.bissell.com/images/UserGuides/1950C.pdf
If this does not match with your model suggest you try browsing or searching the Bissell site to see if you can find a closer match.
Mar 24, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
Need to download PDF format Parts Manual for Bissell 1950-3 Quicksteamer plus -- is there one available?
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Sep 19, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
I have a bissell quickwash model 1950 j 02175. it
the pump belt is off or broken, sometimes when you put too much soap or cleaner in device the belt will slide off the end of the roller, use pinesol to clean this works and doesn't do that, not too much cleaner.
Jul 19, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
Where can i order a quicksteamer plus 1950 clean water tank?
I had a look at the Australian variant of this model and located parts number 407-0931 Clean Water Tank.
My best suggestion is that take this part number and contact your local Bissell Service Center, go to the Bissell International website to locate information for your country.
May 26, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
Diagnosing the problem with my bissell quicksteamer plus upright
Was the exposed copper wiring on the electrical cord? If is then replace the cord. The main problem with this model is that Bissell obsoleted it as well as parts for it. But if all you need is a cord, you should be able to get one from a repair shop.
Mar 07, 2008 | Bissell 1960-3 QuickSteamer Plus Upright...
No suction
Bissell has made this model along with all of the older cleaners obsolete along with the parts for them. I would buy new.
Sep 05, 2007 | Bissell 1960-3 QuickSteamer Plus Upright...
Quicksteamer
Below is link to the directions for use for your vacuum: http://www.bissell.com/images/UserGuides/2070.pdf Just download to your computer and view with a pdf viewer or print it. Good luck.
Jun 13, 2007 | Bissell 1960-3 QuickSteamer Plus Upright...
Vacuums Logo
468 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
