Question about Vizio GV42L 42 in. LCD Television
I have a Vizio GV42L LCD HDTV. The remote no longer is able to work the TV until it is moved closer tothe unit. I have tried another remote from my cable compnay that could work the TV but I get the ame result. What are the possible fixes.
    Master:
  • 518 Answers
On the front bottom of the TV there is a little round eye. If that eye gets blocked, it'll reduce the range of the remote. Make sure there's nothing in front of it. Other than that, the sensor behind the eye could be bad.
Hope that helps...
Geno
Posted on Apr 03, 2008
  • sherry orban
    sherry orban Feb 20, 2014
    can you fix the sensor
Parental control issue
every one for got the code
how do we reset the code
Posted on Apr 26, 2008
GV42L vizio tuner
Your vizio has an internal digital tuner. When you are on air, make sure that it is set up for digital. It might say DTV. Some sets have an analog only and digital only program option in the user menu, or as a seperate input. When in doubt, check your user manual.
May 02, 2012 | Vizio GV42L 42 in. LCD Television
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
How do you switch to cable without remote
On the Unit itself, are Buttons, up to seven, 7, of them, usually, ON/OFF, MENU, Channel Up, Down, Volume Up, Down, SELECT/ENTER, Nearly ALL functions available on the remote can be performed via the buttons on the TV. Simply choose menu, and Step through with the Channel & Volume keys, and "Selecting" with the select/enter key. www.scribd.com/doc/.../VIZIO-GV42L-HDTV-Service-Manual
static.compusa.com/pdf/GV42L_HDTV_User_Manual.pdf - United States
Above are your User manual, above that is a service manual.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
Vizio GV42L 42inch LCD/HDTV
there are several possibilities. first if the unit comes on and the "VIZIO" light turns white, but no picture or sound, then the main control board is most likely the issue. could be the LCD control board(s) depending on model one or two. and ultimately could be the power supply on the upper side....if the "VIZIO" light does NOT turn white, the whole power supply unit is out. after that, would have to scope the circuits to find out. Seems that the control board is the most common and tends to happen on many different sizes. new board will be around $350.00. Might get lucky and find a used one, but it MUST be EXACT part or it wont work right. if you dont find one or want to sell yours for parts, id be interested in the screen. can reach me at kmarlin@grandvalleygolfclub.com. thanks, keith
Jun 27, 2009 | Vizio GV42L 42 in. LCD Television
VIZIO GV42L Remote seems to have lost memory and wont work for TV
it may be the receiver in the tv i would start w/possiable bad solder connection which is not rare, okay but most likely reciver is no good
call tv shop if still under warranty should be in good shape good luck
May 07, 2009 | Vizio GV42L 42 in. LCD Television
My remote wont work with my tv
The receiver for the remote is on the right side. Do you have something in front of it? My remote will not work if there is an object on that side of the TV.
Apr 09, 2009 | Vizio GV42L 42 in. LCD Television
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
May be a bad power supply, which is a common problem with these units.I have a GV42L 42" manufactured in march 2007. It works perfect except the screen has a fracture on it. The warranty is voided because we damaged the screen. I can sell this to somone who has a good screen but needs boards or speakers, etc. Or I will buy your tv that has a good screen but damaged boards in it.
camckay7626@yahoo.com
Aug 13, 2008 | Vizio GV42L 42 in. LCD Television
Vizio GV42L 42 in. LCD Television Logo
377 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
