When i turn on my pc the start up is desplayed on my lcd ag neovo f-417 monitor but when it goes to load the windows the screen goes blank
Your memory has more than likely taken a vacation. This is the most common effect when it does and depending on the reasons for it deciding to no longer function for your computer, It may at times work (sluggishly so) but usually not. When it goes... it's generally gone out for the long haul. Your computer still sounds like it's working but the processor just cannot get signals past the memory. When installing memory, make sure that you are using prescribed RAM for your motherboard. Take care to not underscore the amount of Ram you install as some boards utilize onboard memory as it's casche in Video Chips.
Another prospect is that you lost Windows. Try reinstalling it but i'll bet that's not your problem as Windows is pretty good about trouble shooting itself and warning you of a problem. I learned it as..."NO WARNING...NO RAM".
Posted on Apr 03, 2008
6ya staff
SOURCE:
Driver for neovo F417 lcd screen windows 7
No drivers are necessary. If Monitor is seen as "Plug and Play monitor" is ok.
Mar 07, 2011 | Neovo F-417 17" LCD Monitor
I boot and my screen is hit and miss, so screens i see most i do not. worked intermitent, so times it would work, then it just stopped all together. i replaced the monitor and it works just fine. i then...
Which version of the monitor do you have? Built-in power supply or external AC adapter?
http://www.agneovo.com/us/content/f-417.asp
or AC adapter: http://www.usadapter.com/LCD-AC-Adapters/AG-Neovo-F-417-LCD-Adapter-12V-4A.html
If it uses externa; AC adapter, then you need to attach a car bulb such as 1157 using high filament to the adapter output and see if it still putting out 12vdc with load.
If it uses built-in power then you need to check the power supply section first.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 09, 2010 | Neovo F-417 17" LCD Monitor
I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN GOES BLANK AFTER ABOUT 5 SECS. TURNING OFF THE MONITOR THEN TURNING BACK ON BRINGS THE SCREEN ON FOR APPROX 5 SECS BEFORE GOING BLANK AGAIN. THIS IS REPEATED...
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
I own an AG SX 17 neovo monitor, which I got from my company; as they were going to throw it away because the light of screen decreased and after 2 seconds the screen would go blank. When I turn it off and...
a lot of monitors are having trouble with defective capacitors in their power supply ...the bad capacitors will usually have their tops buldged up .. they are not expensive but you would need to know how to solder and basic electronics .
Apr 02, 2010 | Neovo SX-17A 17" LCD Monitor
AG Neovo X-17a
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 16, 2009 | Neovo AG 17" LCD Monitor
Occasional Distortion
For some time we used to sell these monitors in our store. Some of these same models do have a defect which can cause some of the problems you all are having. Neovo does come with a good warranty, at leasted they did when we sold them at the store lasting at least 3 years. We had a monitor that had random blue stripes which Neovo replaced. One thing you may want to try before throwing in the towel on your monitors is reloading the device drivers on the montor. These monitors came with a CD. If you cannot find it you can get the drivers from here http://driverscollection.com/?H=F-419&By=AG%20Neovo . If you think you are still under warranty, give Neovo a call they will may just replace your monitor with a new one. Good luck....
Jul 10, 2008 | Neovo F-417 17" LCD Monitor
Screen goes black in half a second....
Call the service dept. in the above post. Tell them the model and serial number of your monitor and order a backlight inverter board(approx. $35 plus shipping). Open up the monitor and plug it in, should fix the problem. This problem could also be caused by one or more backlights(small flourescent tubes) being bad. I just fixed a Neovo F-417 display by replacing one of the backlight assemblys. I also just fixed a Neovo E-17DA monitor by replacing the inverter board.
Oct 30, 2006 | Neovo E-19A 19" LCD Monitor
Open Questions:
Computers & Internet Logo
50 people viewed this question
Ekse
Marvin
Marvin
