Question about Vacuums
Attachment hose sucks up dirt and after a few seconds blows it back out
    Problem Solver:
  • 12 Answers
You might wanna check if something is blocking the hose. also try to empty the vacuum and clean the filter / filters. please post and let me know what happens. good luck.
Posted on Apr 03, 2008
8900 Riccar upright. Hose when attached works fine but when in agitator mode, it blows air instead of sucking
I can't be sure without knowing more details of where yer air is coming from but I'm guessing if you have good suction at the hose but it's leaving dirt behind when you put the hose in the port at the bottom you may have a clog in the lower suction tube. Remove the bottom plate and inspect the tube the dirt flows into by the brush roll.
Jan 17, 2017 | Riccar Vacuums
I love the machine because it sucks up the dirt but it also sucks up the rug fibers and is clogging the hose. How to I clean out the hose?
Try this - run a strong string with a small weight attached down through the hose. Tie a small rag or a sponge to the end of the string and pull it back through the hose.
Dec 04, 2016 | Vacuums
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Bissell Powerforce Turbo is blowing dirt instead of sucking it up! Canister and filters are clean. Help???
there might be a clog down in the nozzle hose or in your main attachment hose. check for suction.
Jan 03, 2010 | Vacuums
Dirt devil vacuum has suction on bottom but not on hose
Follow the hose to where it goes into the body of the vaccum, you should be able to release it, you more than likely have something lodged in the hose or at the connection joint, Strech the hose once it is disconnected to make sure nothing is still lodges in it.
Hope this helps, If so please rate accordingly. Thanks, David
Mar 19, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Dirt Devil Upright Bagless Vibe Vacuum no longer sucks
Sounds like there's a clog in the long hose that connects to the dirt canister. Remove the hose completely and check for clogs. There is a blue plastic piece that the hose is attached to. You can remove it by taking out the two screws in the back, and the four screws behind the dirt canister. Once those are removed, the hose comes away from the vacuum with the blue plastic piece attached. That should allow you to check for clogs. If necessary, take the hose outside or a place that is well lit, so you can visually verify the absence of clogs.
Mar 09, 2009 | Dirt Devil M087700SV Bagless Upright...
Bissell proheat blowing out air instead of sucking in air
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vm,v
Feb 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
I have a bissell power force vacuum and I just pulled the bag out to change it and when I put it back in it began blowing air out the filter on the side and is no longer sucking
Try checking the attachment hose for clogs. It should come completely off of the vacuum with just a few screws. Also, check the little hole underneath the brushroll where the dirt goes in. Hope this helps...
Marci
Nov 25, 2008 | Vacuums
Blows dust and dirt out of brush area
Did you make sure to cut all the strings, hair, etc. out of the brush attachment on the bottom? Look in the corners too to make sure none has gotten stuck on the sides that needs to be cut out.
Jun 03, 2007 | Kenmore 25812 / 25813 Progressive Bagged...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
54 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
