After I changed ink cartridges on my Lexmark ExecJet IIc printer/scanner/fax/copier, and shut teh top down it comes up with error: 0502 When you lift the top up again the print head does not move across, just stuck on the left hand side Cheers, Edith van Dommelen Tel/Fax: 61893006103 Mob: 61413887318 Email: gtiedith@zeta.org.au
  • 758 Answers
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridgeAfter I changed ink cartridges - 1.gif carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable1.gif from the back of the X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges1.gif.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up1.gif to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
If that doesnt work let me know..
Please rate accordingly
Thank You
Computerrep
Posted on Apr 02, 2008
  • 97 Answers
Hardware Error: 0502. On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a tissue and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
Please rate solution!
  • 19,396 Answers
First disconnect the printer from power and connect it back.
  • Ginko
    Ginko Apr 02, 2008
    From Lexmark support:
    Hardware Error 0502 on LCD Display
    Cause
    The encoder strip may have gone out of range of the sensor, or it might be dirty.
    Resolution
    You need to check the encoder strip on the printer. This is a clear
    carrier.
  • Switch off the printer using the power button.
  • Disconnect the power cable from the back of the Lexmark X5100/X6100 Series.
  • Leave the power cable disconnected for 30 seconds.
  • Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
  • Take out both cartridges.
  • Place an index finger on the encoder strip on either side of the cartridge carrier.
    The red arrow points to the encoder strip. Click here
  • for an enlarged view.
    1. On the back of the cartridge carrier, there is a small slot that
      then back up to get it into the slot.
    2. Lightly press the strip first to the rear and then forward, if necessary.
    3. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
      Click here for an enlarged view. The contacts on the back of the cartridge carrier are the ones to clean. Use a dry tissue.
    4. Reconnect the power cable and switch the printer on again.
    5. Perform the hardware test first without cartridges and then with both cartridges. Click on the applicable document below.
      How to Perform the Hardware Test on the Lexmark X5150
      How to Perform the Hardware Test on the Lexmark X6150/X6170
    6. Make a standalone copy.
    7. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
    If it does not work try the solution proposed on this website.
    Regards
Dell Printer A940 Hardware error
Error 0502-Carrier Stall indicates a physically blocked carrier. This condition can occur for many possible reasons. Most often, the carrier is blocked because the ink cartridge lids are open while the printer is on (Figure 1).
Figure 1: Open Ink Cartridge Lids
Back to Top
» Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
    new_note.jpg Note: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press Select.
new_note.jpg Note: For more information about reseating ink cartridges, refer to the Maintenance or Ink Cartridge Maintenance section in the Online User's Guide.
Back to Top
» Reposition the Encoder Strip
  1. Remove the power cord from the printer.
  2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
  4. Gently move the top part of the printer belt to the right.
  5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    Figure 1: Inkjet Printer Encoder Strip
  6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
  7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
  8. Once the encoder strip has been re-seated, close the scanner lid.
  9. Re-connect the power cord to the printer.
Jul 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X160 doesnt Copy or print faxes
I have been getting a remote fax error often enough that's it's becoming a nuissance. Any suggestions on how to fix this problem?
Apr 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X160 is not printing at all or receiving Faxes. The error that keeps coming up is Hardware Error 0502. Please Advise.
ok sir pls see the link this is the helpfull for the error 0502 in lexmark x160 all in one inkjet printer...ok
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Changing ink cartridges?
I have a dell printer, scanner, fax ect.
The printer and scanner won't work now. Keep getting message, " hardware errpr 0502, when printer starts up, gives a loud click noise.
How do I fix?
Mike Murphy mmurphy8015@yahoo.com
Jan 04, 2009 | Dell A940 All-In-One InkJet Printer
Cant receive a fax
HI try this its from the lexmark web site
Hardware Error 0502 on LCD Display ID:ENUS16536
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
5. Take out both cartridges.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
Nov 21, 2008 | Lexmark X6170 All-In-One InkJet Printer
Error 0502
hi!!!
try to remove the cartridge of your printer
and put back on!! properly!!
may be your printer cartridge
not in ilignement!!!
Sep 21, 2008 | Dell A940 All-In-One InkJet Printer
Lexmar X5150 Printer whit Hardware error 0502, can you Help Me?
http://search.lexmark.com/printer/US/en/17K0000
Download and install updated drivers from this link. If you need a walk through e-mail me your number and I will help you if you rate this fixya. Geokohler@gmail.com
George
Jul 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All In One Printer
if ur getting black pages whn copying it shows that the scanner is defective. call lexmark tech support 800 332 4120 & have them give u a 20% discount to buy a new printer
Jun 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
ERROR MESSAGE : 0502
Hi gtiedith, sometimes the carridge just gets stuck. Leave the lid open. Power off the printer. Clean the carridge metal rod with a tissue. (Just a little wipe should do it. Than grab the carridge & slide it to the right about 2 inches. Close the lid & power on the printer. It should be just fine. Print a test page if you want to.
Have a good day!
Mike
Apr 02, 2008 | Office Equipment & Supplies
Cartridge stall
I have a lexmark x5150 printer, scanner, copier, and fax machine. I keep getting the message: hardware error 0502. The cartridges are stalled on the left side and the printer won't do anything. Can someone help me??
Feb 18, 2008 | Lexmark X5150 All-In-One InkJet Printer
102 people viewed this question
jasbo
jasbo
