Question about Dryers
Renovating my basement,and planning for a gas dryer. Whatkind of in-wallconnectionsshould be used, and location on wall for a stackable waher/dryer system?
  • 110 Answers
You need to first find out the best method of running your gas line to the location of your dryer..Make sure you also run a vent hose to dryer to the outside of your house, make sure you have 120 volt outlet, i would also run a 220 line as well just in case you need 220...
marclavoris
Posted on Apr 03, 2008
How to use stackable washer and dryer if unstacked
stacking was just a gimmick to save space
put the drier on a suitable stand , table or it is possible that there are holes in the back section for a mounting bracket to hang it on a wall
Sep 30, 2016 | Washing Machines
I was offered an electric stackable Frigidaire stackable washer/dry GLET1031; the catch is that it has to be separated to get it out of the basement due to the stairway. Can they be separated? How?
Normally there are 2 brackets joining the two machines at at the back that have to be removed. Then if there looks like a collor around the join of the two machines then you need to lift the top machine by a few inches to remove it from the machine.
Sep 30, 2014 | Frigidaire GLET1031 Top Load Stacked...
Can a stackable washer and dryer be both gas and electric?
yes, the washer is electric, and the dryer could be gas, all though i have only seen in a stackable modles that i use to eliver for sears, that it was also electric, thats not to say thatthe anufacure does not make it
Mar 29, 2011 | Washing Machines
Kenmore 417.84042500 stackable gas dryer. Started
It sounds as if the bearings in the dryer have gone bad. The same thing happened to my dryer.
Oct 22, 2009 | Kenmore Dryers
Dryer works but doesn't get clothes dry. They're
Sounds like inadequate air flow through the machine. In order for the any dryer to function air is forced through the machine and outside. If the discharge is blocked or obstructed in any way the moist air will not be removed, and the clothes will not dry.
Disconnect dryer from wall and clean the wall outlet and and dryer discharge pipe.
Also, if you are trying to force air higher than 6 feet up the wall from a basement you will need a booster fan on the piping.
Sep 15, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
We have a stackable unit and whenever we have to unplug it, the dryer will not heat. Is there a reset button?
can you describe to me alittle more in detail what your doing and is it electric heat
Jun 01, 2009 | Frigidaire Dryers
Turn off buzzers
I had the same problem and the buzzer was one of the worst sounds ive heard. But, I found the buzzer and turned it off for good. Open the front panel and look for a small part in between the 2 main curcuit boxes.I have a Fridgidare stackable combo FLEB8200FSO. On mine this small part is number 144547100. Look for two black wires, one goes to H and the other to C. Disconnect both wires and no more buzzer!! Good Luck
Mar 29, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Maytag stackable washer/dryer gives off a lot of moisture
you answered your own question, its not producing to much miosture, its not releasing hte moisture with in the clothihng, Id be willing to bet that you have a MAJOR clog within the venting!!!!!!
Mar 28, 2009 | Maytag Dryers
Dryers Logo
50 people viewed this question
Top Dryers Experts
