Question about Radio Shack Cinego D-1000 Multimedia Projector
Unit went off when plug was accidentally pulled wont go back on
You said open up and repalce the fuse. What do I open? Where is fuse?
Thanks
J
  • 563 Answers
Hi Jay
Ok take of the top cover by unscrewing it from the sides and bottom.
Then check on the board that has the AC inlet on it for the fuse.
Posted on Apr 03, 2008
Blew fuse bose 321
When a fuse turn black, you have a serious short inside. Repalcing the fuse will do nothing. For more information, please visit my website at audioserviceclinic.com. You may contact me directly through the website.
Feb 06, 2014 | Bose 3 2 1 GS Series II DVD Home...
Pulled the choke bike wont start
Usually if you flood it (by overchoking), you open the throttle wide open (to draw in more air to lean the mixture) while cranking starter.
Beings you had the spark plugs out you could have cranked it then, and let the engine compression blow the excess gas out the spark plug holes.
Jan 12, 2014 | 1990 kawasaki VN 750 Vulcan
I have a Pioneer Power amplifier which stopped working suddenly. I opened it and I don't see any damage or burned surfaces. It has accumulated somewhat dust, but somewhat told me not to vaccum it. Please...
the dead power could be a fuse either on your plug or at the back of the unit is a small round cap where the fuse is for the unit try repalcing these first. you can vac the unit only you need a vac with a rubber hose only on the end and use a light soft paint brush to get the dust off. it caould be there is thermistor temp sensor that click off vac out first with the unit disconnected from power and check the fuses .. let me know if this works as I might have a manual somewhere for it. Good Luck A
Aug 26, 2009 | Audio Players & Recorders
Wont do anything, not even drain
Try unplugging the unit for 15 minutes then plug it back in. If that fails it sounds like the inline fuse which means you will have to pull out the dishwasher and look near the pump is blown and fuse needs to be replaed
May 26, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Garage door went up..but now wont work
It sounds like the trolley (the thing the door is connected to) is jammed against the bolt just in front of the motor unit. Remove the bolt and then run the opener until the door is closed. Now locate the 'up limit' control on the side of the motor unit and turn it about 4 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Mar 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Power went out, freezer will not turn back on
Hi Robert,
Happy to help.
You can go online to the manufacturers web site and download the manual!
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 15, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Plug came out when on and now it wont go back on
HI there
Open up the unit and replace the fuse , should do the trick
Mar 28, 2008 | Radio Shack Cinego D-1000 Multimedia...
Jensen VM9311/ UV7i wont turn on!!?
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at Darkintel74@aol.com.
Mar 03, 2008 | Jensen VM9510 Car DVD Player
Accidentally plugged the 110V to a 220V
you,ll have blown the PSU.
there maybe an internal fuse, located in the PSU. but if smoke was bellowing out, i,d say it went straight past the fuse.
New PSUs the best bet.
Mike @ Compurepair.
Feb 22, 2008 | Computers & Internet
78 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
Frank Zabroski
Frank Zabroski
xxxxxx xxx
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
