The fog lights on most vehicles sit directly underneath the headlight bulbs. The ballast and wiring work just like the headlights, so changing them takes not much time. The procedure to change the fog light is as follows:-- 1) Open the hood and reach down underneath the headlights to unplug the electrical plug from the fog light assembly. Squeeze the top of the release tab and pull the connection off the bulb's ballast. 2)Turn the fog light counterclockwise to remove it from the fog light housing. 3)Install the new fog light bulb.Then connect electrical plugs properly. 4) Test the fog lights by turning it ON. Thanks. you can rate this solution and show your appreciation.
Testimonial: "THANY YOU MUCH!!!!!!!!"
SOURCE: Changing bulbs in fog lights
Hi this is a bit of a hair raiser, first of all you need to turn the wheel all the way into the motor, left or right depending .
The plastic cover underneath is only held on by some screws and retainers take these out, the cover will be loose but won't come out, gently pry it away from the fender, reach behind and unscrew the bulb housing. Be warned there are two or three different bulbs on the market take yours out before heading off to your local spare parts dealer, it might save you the time of having to go again.
hope this helped
regards Warren
SOURCE: how to change fog lights bulbs on my 2005 honda
To Install:
SOURCE: 2002 fog lights
most fog light systems are in sealed enclosures.they do this to keep out water because they are so low to the ground. so your not going to be able to put new bulbs in. you are most likely going to have to buy new enclosures from a dealership or other company.
SOURCE: how do i change my fog lights to my 2004 dodge neon
you need to remove the 2 nuts from under the fascia that hold the assembly in. this will give you access to the bulb
