Question about GPS
Magellan roadmate 760 freezes on the user screen and will not shut off
  • mnfish Aug 21, 2008
    My magellan roadmate 760 freezes when loading a route. I've contacted magellan many times and all I get is re-initialize the unit or send it in. Anyone have any other ideas as to how to fix this? Not a big magellan fan now
DanEz007
  • 86 Answers
SOURCE: Magellan Roadmate 760 won't stay on
U6 is what I think it's called. those cases weren't exactly built around the insides.. (the circuit board).. there's a small IC chip on the backside of that same card with the cradle connect. . more then likely your case has shoved off a tiny little black IC chip. if you open the case and you see a little black peice.. save it. you might have to take apart your unit though. . careful when your opening it as the RF cable will be a hazard as soon as you crack the case.. so open the case just a little bit.. then find that cable I'm talking about.. and just pull it off.. then you can open it without any further restrictions.. If: this small IC chip is the problem, then you either need to solder it back on yourself.. or have someone else do it. So.. if you open the case u pand this isn't the problem let me know.. don't put the unit back together yet. and let me know. _+Daniel
Posted on Apr 29, 2007
montecarlo
  • 50 Answers
SOURCE: Magellan Roadmate 800 freezes
i have a 800 also but it does not freeze because i make sure it is up to date on all firmware and software,if i was you chk out for updates on the magellan website after you register your unit then if ther is, which i know do the update and you will have no problems after that.let me know how it goes.
Posted on Jan 06, 2008
SOURCE: magellan roadmate 3000t not working properly...
map file will not boot. push the RESET button with the bent end of a paperclip located on the right side of the unit next to the power supply input.
Posted on Oct 18, 2008
  • 1111 Answers
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
Posted on Jun 15, 2009
SOURCE: Magellan Roadmate 760 map update problem
Just push the antenna firmly back into the base; it pivots on a coax connector.
This is typical when you drop it.
The antenna is removable.
Posted on Jun 17, 2009
Magellan RoadMate
The map software has become corrupted..
Please rate my help++++Thanks for using FIXYA
Oct 09, 2009 | Magellan Roadmate 760 GPS Receiver
How can I get the code to unlock the European map Magellan Roadmate 760
You will need to pay Magellan for the authorization code, they are the only one that can provide you with an EU code for your Magellan 760 RoadMate. Sometimes Auto Nav 2000 Plus, Inc can also assist. They have direct connection with Magellan to assist issues with Magellan products. Good Luck
Aug 04, 2009 | Magellan Roadmate 760 GPS Receiver
I need an upgrade for my magellan Roadmate 760
You can download an upgrade for this unit from the Magellan website for free. Maps can be upgraded but they cost about $80, and that doesn't seem worth it to me. See if that works for you.
Dec 13, 2008 | Magellan Roadmate 760 GPS Receiver
Roadmate 760 Password Reset
Dark,
Although it has been some time now since I've worked on these, I beLIEve if you plug the unit into your computer you can explore the files and there should be a file called password or pwd or.. something along those lines.. all you have to do is delete the file and it will work. It was surprisingly easy I remember that much. If this doesn't work, play/look around with the files in the unit, and as a precaution I would copy the file over to your computer prior to deleting just in case.
-Daniel
Oct 02, 2008 | Magellan Roadmate 760 GPS Receiver
My Magellan Roadmate 760 turns on and brings up the Magellan screen and then it locks. Can anyone help.
Sep 02, 2008 | Magellan Roadmate 760 GPS Receiver
The weakness of the 760 is the cradle. Is the power wire or the cradle loose or wiggles? You may need to buy a new cradle if that is the case. They are expensive. I soldered my power wire right into the cradle and it worked fine.
Aug 26, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
Downloading new version 6 to my roadmate 700-760 gps
I had a very similar problem downloading the new version for my roadmate 700 as well. I chose to shut system down .I then unplugged everything. I reinstalled the dvd into my computer.I powered up the roadmate700 and hit the enter button and the screen came up to pick user I hit user one. I plugged the USB calble in and started the download again and it worked out for me just fine. I hope this works for you also. Good Luck
Dec 21, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 760 Freezes and Restarts
Chgorose, It sounds like the hard-drive is for lack of a (better)technical term.. crapping out on you. You tried the "GPS data reset" but in that same menu ("secret menu") there's another option that says reset user data (not GPS). I would try this before paying for repairs. If you have software that you can reload then reload the software as it could either be a software issue or hardware (hard drive) issue. As far as a recommendation for future GPS purchases under $600, I'm bias towards Magellan's simply because I've worked on them before and know them. Although the 6000T is nice I do believe it is still above $600, but if I was to get one I'd go for the MRM800 or 860T. Hope this helps. -Daniel
Jun 04, 2007 | Magellan Roadmate 760 GPS Receiver
GPS Logo
107 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
