Question about KitchenAid KEBC247 Electric Double Oven
Clock The hour is somewhat dim,but the minutes are barely readable.  is it broken?
    President:
  • KitchenAid Master
  • 2,651 Answers
Well I theres aproblem with the microcomputer, and would need to be replaced to fix the "dimming" numbers, didnt get full model, but check the partial number supplied and the board alone can cost from 180-325. how old is the unit. smettimes depending on model the manufactuer will warrantee part for 5 years.
Posted on Apr 03, 2008
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
DIM DISPLAY ON GE PROFILE WALL OVEN
when they are dim like this,it needs replacing as its a driver chip that drives the readout and illuminates it you can send in the board for rebuild or purchase outright,as they dont supply any component specs to repair the control panel
Feb 03, 2013 | Ovens
How to set oven timer on a GE electric stove
that is not a problem. I copied the instructions straight from the manual which you can also review by clicking here.
Using the clock and timer.
To Set the Clock The clock must be set to the correct time of day for the automatic oven timing functions to work properly. The time of day cannot be changed during a timed baking or self-cleaning cycle. Press the CLOCK pad. Press the HOUR and MIN + or – pads to set the time of day. Press the START pad. Make sure the clock is set to the correct time of day. To Set the Timer Press the KITCHEN TIMER ON/OFF pad. Press the HOUR and MIN + or – pads until the amount of time you want shows in the display. The maximum time you can enter in minutes is 59. Cooking times more than 59 minutes should be changed to hours and minutes. For example, enter 90 minutes as 1 hour, 30 minutes. If you make a mistake, press KITCHEN TIMER ON/OFF and begin again. Press the START pad. After pressing the START pad, SET disappears; this tells you the time is counting down, although the display does not change until one minute has passed. Seconds will not be shown in the display until the last minute is counting down. When the timer reaches :00, the control will beep 3 times followed by one beep every 6 seconds until the KITCHEN TIMER ON/OFF pad is pressed. The 6-second tone can be canceled by following the steps in the Special features of your oven control section under Tones at the End of a Timed Cycle. The timer is a minute timer only. The timer does not control oven operations. The maximum setting on the timer is 9 hours and 59 minutes. To Reset the Timer If the display is still showing the time remaining, you may change it by pressing the KITCHEN TIMER ON/OFF pad, then press the HOUR and MIN + or – pads until the time you want appears in the display. If the remaining time is not in the display (clock, delay start or cooking time are in the display), recall the remaining time by pressing the KITCHEN TIMER ON/OFF pad and then pressing the HOUR and MIN + or – pads to enter the new time you want. To Cancel the Timer Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
Aug 28, 2010 | GE JTP20 Electric Single Oven
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
Jenn Air JJW8530C stopped working
can you hear audible tones form the machine when trying to set?? and just hte display has dimmed( amore normal complaint). all functions are working just the clock/display has dimmed to non readable state. if thats the issue youll need to replace the display part number 71003424 retails for about $165
Nov 04, 2008 | Jenn-Air JJW8530C Expressions Collection...
Smeg oven SA392EB cannot reset clock
Turn off at mains, turn on again. 0:00 will flash press the manual op key ( on mine button on right) use +/- keys to set the time. Don't use buttons with wavy lines as they are for setting auto cooking time.
Oct 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Jul 07, 2008 | DCS (WOTD-227) Double Oven
Clock display too dim
You are going to need a display kit to fix this. It comes with a new display and relay board. The kit is about $200 and is somewhat difficult to install. This repair altogether usually runs about $400 to fix if you dont have someone handy that can do it for you. It involves removing and replacing at least 20 wires from the relay boards, as well as either pulling the oven from the wall or working in a tight space to change the board. You may be able to find just the display board somewhere, and that is very easy to install, but I've only ever gotten the part as a kit. Hate to be the bearer of bad news. Good Luck!
Aug 16, 2006 | Thermador C301U Electric Single Oven
KitchenAid KEBC247 Electric Double Oven Logo
78 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
