Question about Video Game Consoles & Games
Sixaxis controller problem
My six axis controller's Joystick is sort of lose with excessive playing. (Which usualy happens for excessive use). My question is this that is there any way that this could be fixed back to normal like it was before
    Problem Solver:
  • 9 Answers
Is either getting a new one or try to swap out a good Joy stick from another controller, I am having the same problem and I already gone thru 4 controllers. I really wish they can fix the Joy stick slacking so easy................................ at 53.00 CAd a pop which normally last me no more than 10 months+.
Posted on Dec 05, 2010
I'm currently trying to play heavy rain and at the very beginning when it prompts me to shake the controller it doesn't register, ive googled ten different versions of my question and i get nothing...
Well, it's simple. what kind of controller do you have, and how old is it? the 2 Sony six axis controllers i bought with my ps3 had buttons that stopped working on them. so it is possible if it is an old controller that the sixaxis just simply "went out" BUT when psn does go back up tomorrow download the little big planet demo or pop the game in if you already have it. it uses the sixaxis to move their heads. GTA4 also has sixaxis parts to it. and you can access that in the phone menu while playing the game. But you might just have to buy another controller if yours isn't working. Hope it helps!
May 03, 2011 | Sony Playstation 3 (PS3) Console
My computer is unresponsive to the joystick; I plugged it into the usb port a message confirmed it was installed and ready for use but nothing happens when I move the joystick in a flight simulator or...
Hello, Here's the solution to your problem, you have to configure the games you're playing for the joystick to work, I believe all games have this option, ussualy in the "configure keyboard and mouse" options menu, click on any funcion you want your joystick to use for each button, and then press the button you want for that function, do that with all buttons of the joystick you want to use, some games need the joystick axis to be configured, just click on left/right and move your joystick in the desired direction, same procedure to up/down, if your joystick has a throttle wheel, do the same for it (if needed).
Procedure is simple and most games has small variants of this procedures I gave you, but they are simple to figure out.
Hope my solution helps, have a nice day :)
Apr 14, 2011 | Trust Predator TH 400 (12629) Joystick
I restored my ps3 because my wireless controller wasn't syncing with my playstaion so I restored the hardware and now all the screen says is connect the controller via USB, have tried and reset controller...
Try to reset the SIXAXIS it is a small button located at the top of the back of the control.
If that fails, try this. Plug the mini-USB port end of the USB cable into the PlayStation 3 controller while connecting the standard USB port end of the cable to your PC.
Wait for Windows to report that it has "Detected New Hardware" and let Windows go through its full scan. When Windows says that it could not recognize the hardware, the scan is complete Download the appropriate drivers for your controller, either SIX AXIS or DUAL SHOCK 3 (it is written on the top of the controller).
These drivers can be found on several websites by doing a Google search for "PS3 Controller PC Drivers Unzip the driver files from the zipped folder to someplace easily accessible on the hard drive (such as your desktop).
Double-click the Setup icon and follow the directions given on-screen to install the SIX AXIS drivers Unhook the controller and reset your computer to complete the installation process.
Any further questions feel free to ask.
Dec 06, 2010 | Sony PlayStation 3 40GB System
Hi I have windows vista and im trying to play an old game called USAF 15.. The bottons will work during the game but the joystick will not controll the plane. In my control panel the joystick works fine...
Go into the settings for the game and check and make sure that the game is detecting the X and Y-axis. You might need to check enable joystick or some similar option.
Jan 30, 2010 | Logitech WingMan Extreme Digital 3D...
How many axis and buttons on the Logitech Attack 3?
It is a 2 axis joystick with 11 programmable buttons.
Please rate me if you are satisfied with my answer.
Aug 20, 2009 | Logitech Attack 3 Joystick
X-axis trouble
I had the same problem with my X52 and searched high and low on the internet for a solution. What I did was pop the base off and found a loose connection on the x-axis wires. I re-routed both the x and y axis contact wires underneath the p/s2 port and put it back together. Seems to be working fine now. I will not that opening up the controller will void your warranty and it also could be possible that your x-axis problem could stem from something completely different from what was wrong with mine. You may contact me if you need any help with it. mynameisbob AT gmail DOT com.
Jul 19, 2008 | Saitek (PS28) Joystick, Throttle
Loss of some colour
You have tried
RESOLUTION loadTOCNode(1, 'resolution');To resolve this issue, use the Game Controllers tool to manually add a 2-axis, 4-button joystick. To do this, follow these steps: 1. Click Start, and then click Control Panel. 2. Double-click Game Controllers. 3. Under Controller, click Microsoft SideWinder 3D Pro, and then click Remove. 4. Click Add. 5. Click 2-axis, 4-button joystick, and then click OK. 6. Click OK to close the Game Controllers tool.
Right?
-Rel
Jun 02, 2008 | JVC Televison & Video
Why did the Y-axis stop working?
Same happened to my joystick, it happened when i put the drivers for it on, then i deleted them and it fixed it. Them the Y axis just stopped about 2 weeks later....
Mar 19, 2008 | Apple Logitech Freedom 2.4 Cordless...
Video Game Consoles & Games Logo
43 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
