Question about Dewalt 18 Volt Compact Drill Kit
Chuck replacement I have the one (18 volt) that has a torx retaining screw I took it out and cant take the chuck off is there something else retaining it? I try turning the chuck clockwise and counter and it feels like I am going to break the plastic.. Thanks Paul
  • kingport Nov 06, 2008
    I have the same problem only can't get the center screw out.
    Champion:
  • 313 Answers
If the screw is out. all you have to do is lay down the drill at the edge of the table & use pipe wrench or plumber wrench & turn counter clockwise.
Posted on May 31, 2008
    Problem Solver:
  • 14 Answers
Hi Paul with the screw out you will have to lock the short end off a sturdy allen key in the jaws off the chuck then sellect first gear on the drill then with a hammer hit the long side off the allen key so that the chuck unscrews normal thread (anti clockwise) the shock off the hit will free the chuck.
Hope this helps.
Sean.
Posted on Apr 03, 2008
SOURCE:
My chuck on my dewalt 18 volt comes undone in reverse its fine going forward what would be the problem
If you look at the end of the shaft on the drill after it unscrews, there will be a hole with threads inside--if not the screw may have broken off---your missing screw that holds the chuck on--it's a left handed threaded screw---it's head may be slotted--philips---torx---or allen---this is available at your Dewalt dealer or tool repair---all that needed is the size/model number of unit---screw the chuck back on tightly then open chuck jaws all the way then put the holding screw in---tighten it down---REMEMBER IT'S LEFT HANDED----GL
May 05, 2017 | Dewalt Drills
My keyless chuck will not tightten all the way closed....seems to catch on something
Open the chuck and see if the screw inside the chuck has backed out. The screw is left hand thread so you will need to turn it to the left to tighten it. It may be an allen or Torx head screw.
Jul 15, 2011 | Milwaukee 2690-24 18-Volt Hammer-Drill,...
How to change the chuck on 18 volt cordless drills
Set the drill to reverse. Hold the chuck, press the trigger and open the drills chuck to it wide open position. Now,, take the correct size allen wrench and insert it into the back of the chuck to remove the screw. Turn the screw clockwise to remove it. Notice I said clockwise, just the opposite of what you might think. Hold the chuck with your hand or a pair of large vise grips and press the trigger to unscrew the chuck from the drill. Rotate it counterclockwise to remove it from the drill. Reverse the procedure to install the new chuck.
Mar 10, 2011 | Dewalt 18 Volt Compact Drill Kit
My chuck releases when i use it in reverse.
does the chuck unscrew?? If so what you need to do is tighten the chuck again and look for the chuck retaining screw that locks it into place, you should be able to buy one at any local tool repair center. they are left hand thread. if the jaws are releasing then the chuck might have to be replaced. Let me know if I misunderstood the problem and I will try again.
Jan 02, 2010 | Dewalt 18 Volt Compact Drill Kit
Got a broken drill chuck i cant get off (Dewalt)
first remove the chuck retaining screw LH thread, next shift the tool to the drill only position and the low side. Find a bent handle allen wrench and insert the short piece into the chuck and clamp down, place the chuck with the long portion at about a 30 degree so you can strike it counter clockwise, usually a block of wood or work bench will do and then get a hammer and safety glasses and hit it, it might take a couple times but it will come off
Jul 02, 2009 | Dewalt 18 Volt Compact Drill Kit
I have a older Dewalt recharge drill dd991 14.4 volt I need to
The chuck retaining screw are left handed and the chuck itself is standard right hand. Let me know if I can help further
Jun 19, 2009 | Dewalt 18 Volt Compact Drill Kit
Changing the chuck on an bosch 18 volt cordless drill
Inside the chuck is a left-handed screw. Either torx (star) or flathead, usually. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Lemme know. Please rate me
Jun 17, 2009 | Dewalt 18 Volt Compact Drill Kit
Having problem to remove chuck to replace it on dewalt dc988 18v
Inside the chuck is a left-handed screw. torx (star) T20. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Please rate me
Jun 08, 2009 | Dewalt 18 Volt Compact Drill Kit
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
225 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
