Question about Refrigerators
FRIGIDAIRE GLHS36EEW1 THE TEMP IS MUCH TOO WARM. TEMPERATURE CONTROL BOARD DISPLAY NOT LIT. EVAPORATOR FAN VOLTAGE 25 V ACROSS 51 VOLT ON SIDE TERMS. YOU CAN STOP THE FAN AND IT WILL NOT RESTART ON ITS OWN.
How do I test evaporator to know if it's faulty
Posted on Aug 11, 2008
  • bbmoe Aug 11, 2008
    does a faulty evaporator effect the food section of the fridge, that area is warm also
    Problem Solver:
  • 5 Answers
Does your freezer have a ice buildup on the evaporator....if it does change evaporator fan motor
Posted on Apr 02, 2008
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
How can I get the display controls to change the temperature. For some reason our display will not change the temperature. I checked the manual, but it only says what temps to use, not if we have to...
Error Code FFThis is an error code that indicates a failure with the evaporator fan motor but could also be with the main board. If the evaporator motor is running, then the problem will be with the board. If the motor is not running, some voltage checks will need to be made. The problem could be with the wiring to the motor, the motor itself or the board. These can be some complicated checks and will require a technician. One possibility you can try, will be to reset the board. To reset this board, disconnect power to the refrigerator for a few minutes and then reconnect it. If the code disappears and does not return, it should be ok. If it does not go away or goes away but returns again, you will need to replace the evaporator fan motor.
Jan 24, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
What is er dh?
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
Dec 18, 2010 | Kenmore Refrigerators
Problems for Refrig. Kenmore Elite
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
I HAVE AN ERROR CODE dH on my Kenmore Elite bottom
Apr 14, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Refrigerator warm, display blank but freezer still works
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*#$^
Feb 21, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My kenmore elite trio has error message. ER DH
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$
Sep 16, 2009 | Kenmore 73503 Stainless Steel Bottom...
We have a Kenmore Elite Trio that keeps giving us an error message in the electronic window of er dH
Aug 30, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frigidair side by side refigerator fan not operating
I do see the power to the evaporator fan section going through the adaptive defrost part number 240554502 It would not hurt to unplug for a few moments and open the control panel inside the fresh food section and examine that control board. With it doing that you may see signs of heat or burn marks on the ADC Let me know, Sea Breeze
Jul 21, 2009 | Frigidaire Refrigerators
Er dh code error on Kenmore elite trio
Jul 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
232 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
