Question about Toshiba Satellite A105 Notebook
A 105 screen going black.
My laptop has been put away for about 6 months and before putting it away it was fine now the once you turn it on after a few minutes the screen will go black, but all the power lights stay on and the fan is sitll running like nothing is wrong. i checked all hybernation mode and power saver mode options i could find and it is still doing the same problem. any sugestions would be great.
  • 1 more comment
  • Harper_V Apr 14, 2008
    My computer turns on fine with no problems after a few minutes or so the screen goes black but the computer stays on and the fan is still on. Can you help me and where is the ram located?
  • Anonymous Apr 14, 2008
    computer boots up well .The desktop picture is the only thing on the sceen.What happen to the icons and the start bar?
  • emajean Apr 14, 2008
    Starts up to desktop picture.No icons and no start bar.
  • 77 Answers
First
1. Try to remove the ram and using a pencil eraser, clean the contacts and plug it in and see what happens
if it doesnt work.
2. Remove the AC and the battery, then hold the powerbutton for 5 seconds. and plug the AC adapter and see if it powers up properly.
Posted on Apr 07, 2008
A215 Black Screen
I would recommend you to just buy a new, good, Dell laptop!
Jan 17, 2013 | Computers & Internet
Black screen when turned on
I would check the memory first. If you have two sticks of ram in it. Take one out the try to start it. if you have no luck, switch it with the other one. Then try a restart.
If you have lights but black screen, your video (gpu) may be bad. The fix depends on the model you have. In most cases, it is a motherboard replacement. If you have a DV6000-DV9000 they are notorious for having bad solder. It comes loose and loses connection. You can take the motherboard from the laptop case, heat the gpu for about 30 seconds (with a heat gun), and hold pressure on it for 1 minute. When you put it back together, put silver grease on the gpu and lay a copper shim ( I use a penny) between the gpu and the heat sink. This fix works 75% of the time, but it is not a permanent fix. You may get month out of it, 6 months if you are lucky. You will eventually replace the motherboard
Mar 14, 2011 | HP Computers & Internet
My screen has blue and red lines across it. Now the red lines are becoming stronger and the screen flashes red until it turns off. how do i fix this?
This is for if the lines are thin and in the form of an arc across the screen.
You need to turn down the screen voltage for the blue and red CRT. I believe the access is through the front on that model.
1) Remove the front grill
2) There should be access panel you need to remove once you remove the front grill. This is where the screen voltage adjustment is located
3) Look for a small black box with six knobs on it. One row is for "Focus" and one row is for "screen". It will be marked, but probably need a flashlight to see which row it is. There will be a "R", "G" and "B" next to each knob to represent Red, Green Blue respectively.
4) Careful with the access panel removed, you are only inches away from very dangerous voltages.
5) slowly turn the R or B knob counterclockwise until the lines on the screen disappear.
Keep your hands away from everything else and only use one hand near the tv. put the other hand behind your back.
6) Once corrected, replace the panel and put the grill cover back on.
Feb 19, 2011 | Sony KP-57WS500 57" Rear Projection...
You see red and blue lines curved across the screen when there is a blank screen
Feb 17, 2011 | Sony KP-57WV600 57" Rear Projection...
I get blue line ine the screen when it balck
This is for if the lines are thin and arc.
You need to turn down the screen voltage for the blue CRT.
follow the steps below:
Feb 16, 2011 | Sony KP-57WS500 57" Rear Projection...
About a year ago out of the blue, my laptop screen started turning off but the computer was still running. It has Windows Vista and Ubuntu. The problem was that the screen would start up normally and then...
it sounds like a mother board or graphic card problem
get a proper diagnosis from a computer repair shop but technology is improving every day and laptops are getting lighter and faster so after getting the diagnosis and quote a replacement may be the option to consider
Mar 13, 2017 | Everex StepNote SA2053T Notebook
Switched on my laptop this morning,and i noticed that it took unusually longer to start.Then the black and white screen appeared-it said: "WINDOWS ERROR RECOVERY windows failed to start.A recent...
Hi it may be virus issue. i suggest you to try with last known good configuration so that it will take your computer to last good working state. for that tab F9(Function key) continously immediately once you turn on your computer until you get the advanced option on your screen. highlight last known good configuration and hit enter and it will boot in that mode once you get the main sceen CLICK start - > all programs- > Accessories - > system tools -> system restore and wizard will open and select Restore my computer to an earlier time click next next finish to set your computer to last good working condition. If that doesnt work reinsatll the OS
Dec 26, 2010 | Acer Aspire 4730-4947 Notebook
Dell Inspiron E1505 shows green pixels instead of black
the color pixels are different sections in the screen and the green section might be cracked
Apr 24, 2009 | Dell Inspiron E1505 Notebook
TI 83 screen
I know your problem
Do NOT HOLD the 2nd button instead just press it once and then press the arrows hard. It will work just fine
Oct 03, 2008 | Texas Instruments TI-83 Plus Calculator
try by removing your display adapter in safemode.if problem persists reinstall your display driver.report your findings
Apr 03, 2008 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
