Goldstar 27 I am having a problem with the Video Display on one of my TV's sometimes i can get the picture to display some colors if i mess around with the settings but mostly only green will show .. I have taken some pictures to show what it looks like. I have taken it apart but not really sure where to start at. Any help would be appreciated. Pics are not the best quality the screen dont look all blurry like that lol just the pics came out that way lol but the color is what it looks like mostly all greenish there are 3 pics i took Thanks
  • 2 more comments
  • Steven Boutilier Apr 03, 2008
    Screen looks the same with whatever i watch on it .. and its just running a Digital Cable Wire .. if thats what u mean
    Alright well i am very good at taking things apart computer wise not so much TV wise lol .. I have taken this TV part .. now the Color Transistors are located on the Back of the CRT board thats connected at the very end of the Tube i guess ? how do you disconnect that just pull it away from that clip in the middle? It really dont matter if i break the TV i just like to see if i can fix it. Any Picture Guides or anything would help.
    Alright after while i tired something instead .. i took the board off the back of the tube and i adjusted the dials on the colors .. and i dont have as much green anymore .. i have all the colors now .. except anything thats suppose to be like red is more orange or really dark colored instead. How do you go about fixing this part
  • digiteyes May 11, 2010
    Is this only happening from the tuner, or does it also happen from an external source being connected eg: DVD player?
    If also from DVD.... what AV connection method is used... composite, component etc?
  • 110 Answers
Based on your resonse to my questions, I'd agree with Geno69 that those are the likely suspects.
Posted on Apr 03, 2008
  • 518 Answers
In picture number 2, I saw some blue also. So I'd guess that the red gun is not firing. This could be a transistor on the board on the back of the picture tube, or it could be a bad picture tube. I would replace all three transistors on the PC board, if the problem remains, it's probably the tube.
Hope that helps...
  • Gene Wells Apr 03, 2008
    On that PC Board (Called a screen board), You need to get the number off of one of the transistors, it might look like "C####" or "2SC####" Example C1234 or 2SC1234. You need to find a place that sells that part and buy 3 of them. Then using a solder iron and solder, remove the old one (1 at a time) and solder in the new ones. Then the easiest way to adjust those controls is to get into the menu of the TV and turn the color all the way down. Then adjust those controls for the best black and white picture you can get. Then when you turn the color back up, it should be correct. This is all assuming the picture tube is good.
    You might find the transistors at MCM Electronics.
    Hope that helped...
Uneven brightness problem
This problems are on the video board,that connected to the CRT.The video IC inverter,all the capacitors around it.Some of the capacitors,that help to divert the colors are dead.Don't mess with the CRT Yoke,put it back to the original mark and tighteen it before,u misalign the three colors guns for good.
Jun 28, 2010 | JVC AV-27D202 27" TV
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Color is off on my xbox 360.has a green tint.any idea how to fix this?
You have two options, first: change the display settings on your tv so that the xbox screen looks normal. Or change the color display settings in the console settings menu. Play around with the saturation until it looks right to you. Also, make sure to keep electronics off the top of your tv. I've noticed that this can sometime change the color of the screen in certain places. Hope this helps.
Jul 14, 2009 | Nintendo Wii Console
How to adjust color on sk-32h570d
This is from the MANUAL
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
My tv sound ok, crt high voltage ok,channel number display ok
check for a resistor rated around 220kohms somewhere around the flyback area. i have never worked on this model tv before so i cant give you an exact part number on the board but had the same problem with sharp tvs
Nov 20, 2008 | Philips Magnavox 27MS343S 27" TV
Display Issue
Toshiba makes a great laptop but the display video or lcd seem to go bad very quickly I have replaced the lcd in many to solve this problem but be aware a few also had bad video cards (unlikley in your case as the external video is fine) it would seem as the lcd panel has gone bad on yours. the average replacment is around $100.00 to $300.00 depending on where you purchase from.
Oct 24, 2008 | Toshiba Satellite M115-S1061 Notebook
Sony TV KV 27FS 100 Picture in BW when connected to my Laptop.
connect a dvd to the tv using the same cable.
If the color is O.K. then the fault is in the laptop.
Thanks Guy9
Jul 07, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No colors
sounds like a leaky cap or bad solder connection
Dec 04, 2006 | Panasonic CT-27G23 27" TV
Plasma TV color problem
Sometimes, poor picture quality occurs when having activated an A-VHS camera or camcorder connected and having connected another peripheral at the same time. In this case switch off one of the other peripherals. Also, The norcent has a known problem with progressive scan - when connected to a progressive scan source, it yields a distorted screen with dual images and messed up colors.
Mar 22, 2006 | Norcent Technologies2703 27" TV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
