Question about Konica Minolta magicolor 2400 Laser Printer
Km 2400 magiccolor
I replaced the black ink cartridge and now the balck and color printed docs are all very faint!
  • 4 Answers
Maybe you got at bad cartridge or opening is releasing enough ink
Posted on May 09, 2008
SOURCE:
Can I change to 95 tricolor for a black ink cartridge,,,,we never do any color printing
It won't recognise the black cartridge in the printer and may even throw an error code. Use the black and white option setting for printing.
Sep 15, 2018 | Black Office Equipment & Supplies
Not printing any black text on paper.
Following Occam's Razor, the first thing to do would be to replace the black ink cartridge.
May 23, 2016 | Canon PIXMA MG7120 Inkjet Multifunction...
Black printing very faint or not at all, cleaning print head makes little difference Brand new Cartridge
Sometimes it will print faint black even if there is a new black cartridge, because the color cartridge needs to be replaced as well.
Make sure that the cartridges are genuine Kodak cartridges, as well, for maximum performance and reliability.
Cleaning heads can use up a lot of ink, by the way.
Jan 13, 2011 | Kodak ESP 5 Printer
Won't print black
chack your balck cartridges may be it's finish just tak out seak that will fome to know is the ink of finish
relpace that it will work fine
May 10, 2010 | Brother MFC 490cw Color Inkjet...
I have run out of color ink want to print with black only
all you want to do is to remove the color cartridge then that's it you can now print in color balck
Jan 07, 2010 | Canon PIXMA MX310 All-In-One Printer
I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Please rate this solution. Thanks.
Oct 07, 2009 | Office Equipment & Supplies
The black ink print is very very faint
Indicates that the printer is using only color ink to create a black color. Check printer settings to see if you can set it to use only black cartridge. Also try printing with only the black cartridge inside if the printer permits, this way you can be sure if the black print head is faulty.
Jul 28, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printing color is ok but no black
printer is probably too old . buy a new one
or just print everything out in blue or sumtin other than black.
(thats what i do when my black ink is out)
Jun 30, 2009 | Brother MFC 420CN All-In-One InkJet...
I do not know how to change the black ink on a monolta 2300 ?
http://crm01.konicaminoltaeurope.com/openmind/technic/engineer/qmspubkb.nsf/0/70744652a954e650c1256f820078e0a2/$FILE/MC24x0-Replace%20Toner%20Cartridge.pdf
Goto the above link and it shows the PDF doc. for changing the cartrides.
Jun 23, 2009 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
62 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
