Question about Dryers
I do not remember where to connct my ground wire or live wire on my push to start switch. My dryer is an estate by whirlpool.
  • Dryers Master
  • 19,396 Answers
Which is exactly your model?
Posted on Apr 03, 2008
Why will my estate by whirlpool super capacity dryer will not come on?
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Aug 16, 2014 | Estate Dryers
I have estate dryer by whirlpool that came with a 3 prong cord and I changed it 4 prong because my outlet is ,4 and on my dryer I dont have a bonding strap but a green ground wire connected to the middle...
no,you need to connect the green wire to any metallic part of the dryer,even if the white wire on the neutral terminal has a bonding strap from this terminal to the metallic dryer case as you should never connect more than one wire under any type of terminal unless otherwise specified by the manufacturer
Apr 20, 2012 | Whirlpool Dryers
The WHIRLPOOL TEDS840PQ0 dryer wont turn on. The
Check the house electrical panel dryer circuit breaker pair--push off, then on. Try the dryer again. If still nothing, measure the voltage across the two slanted slots in the dryer power socket. It should measure: ~230 volts AC. If at or near zero, either one of the breaker pair is defective, or a wire is open from the breaker to the socket. If you read ~230 volts, then the problem is within the dryer--motor runs, but drum doesn't turn (broken belt), or motor doesn't run (bad controller, motor, door switch, start switch. Does the unit get hot? Need more help on your end.
Oct 18, 2009 | Estate TEDS840JQ Electric Dryer
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Estate dryer won't come on..
check the white thermal fuse on the blower housing
Apr 26, 2008 | Estate EED4300SQ Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
