My disk drive isn't working. When I put a disk in and close it, nothing happens.
  • manitoh Mar 31, 2009
    hi, i have the same problem with that i cant see the cd drive at all. so i followed the instructions up until the part where you said to "reinstall". i didnt know how to go about ths??
    Novelist:
  • 125 Answers
Firstly lets see if your drive is working!
#put in a disk you know works and has files of some sort on it
#If nothing is still happening , goto my computer and right click on your CD drive and click "explore"
Do you now see files ?
#if not right click on "My computer" and click manage
#the "COmputer Management" Console will now popup and you will see a selection of headings on the left , click the plus sign on "Storage" to expand it then lcick on "Disk management (Local)
#in here you will see all the storage devices attched to your computer , including your Hard Drives , Floppy Drives , USB Flash Drives etc.. , from here you should see your CD Drive , if you do and right click it and explore the drive and you do see files , change the drive letter of your CD-ROM drive from the default D: to say like F: or something , right click the CD-Drive in the Disk management and click change driver letter , and follow the instructions.
#If you dont see the files or you dont see the CD-Drive at all do the following:
1. right click my computer
2. click on properties
a new window will popup
3. click on the hardware tab
4. click on device manager
the device manager console will now open , from within here find your CD/DVD Drive under the DVD/CDROM drive heading, right click the appropriate drive and click on uninstall
now reinstall with the drivers and restart.
also if this doesn't fix your problem try upgrading the firmware of your Drive.
**im assuming your running Windows XP for that solution but i would think the process in Vista would be very similar.
If you have a spare computer that is unused maybe you could try it on that machine and see if it works , if it does a fresh installation of Windows on your current machine may be the solution as it could be infected with a virus which just may have corrupted the window drivers.
Feel Free to ask more if this doesnt fix it:
Thanks!
Posted on Apr 03, 2008
Wow i just uninstalled my disk drive, how do i "now reinstall with the drivers and restart??"
Posted on Jun 16, 2009
2 Suggested Answers
  • 553 Answers
SOURCE: My computer won't read disks.
There's only two possiblities either your driver has been corrupted or the drive itself has failed. Try reinstalling the driver, first find or download the driver for your CD drive, when windows tell you it already has the best driver hit back and tell it to install the driver at the location where your driver is at. If this doesn't fix the problem your best fix is to buy a new CD drive, given the current cost of DVD drives this might be a good time to upgrade.
Posted on Jul 05, 2010
Replaced hd model no # T6420 now it wont boot with recovery disc ?
When you put in the new hard disk, did you ensure that the jumpers on the HD were set to be the primary (boot) disk? Even if you set it that way in the BIOS, the HD must also be set the same way.
Most new hard disks have a template pasted to the top of the drive, which shows which pins must be set or "jumped" in order to make the settings you require. It sounds as if you have the new HD set to slave, not Primary/boot.
Shut down the PC completely, but do not unplug it, as you need the ground for safety.
Open the PC again, and take a close look at how it is set. While you're there, make doubly sure that you have plugged things in properly. If you have the interface off by one pin, it will not work. If you do not have it pushed in tightly, it will not work. These are all little things, but they add up to a non-working Hard Disk.
Go back, look again, ensure that all is set exactly as it should be. If you still have the old hard drive handy, and it is the exact same model as you just reinstalled new, then compare the jumper settings for the two and make sure that the new drive is set the same way as the older drive.
Put it back together carefully, ensure the BIOS is set correctly, so that your HD is the first boot drive, then try to bring it up. To get the partetheses off the drive indicators, you must set them properly.
Also, if you have not yet formatted the new HD and put a system on it, then of course, nothing good will happen, as you are working with a mechanically brain-dead drive. You need to initialize it, format it, then put an operating system on it, like Windows Vista or Windows 7, etc., before it will do anything.
Cheers!
-a.
Jul 15, 2012 | E-Machines eMachines Desktop PC
My hard drive was working properly earlier and now i plugged it into my laptop and it says that i need to format it for it to work, it shows the icon for it on my computer but won't open. I don't...
The disk is dying - hardware defect. Last attempt to save some of your files: take apart the casing and extract the actual hard disk from it; put it directly inside a desktop and try to access it from there. If the disk isn't recognized or you get an IO error when you try then the damage is too great. If you only get a format error you could try this program
http://www.ptdd.com/recoverdeletedpartition.htm
Jul 17, 2011 | Iomega 1TB Prestige External USB 2.0 Hard...
Jul 05, 2010 | Dell Dimension C521 PC Desktop
The disk wont load
What happens if you put the disk in and run the greeting card program? Does it ask you to insert the CD?
If you have AutoRun turned off for the CD drive, nothing will happen when you put it in. And most software install disks are not bootable, usually only OS and Anti-Virus/Anti-Malware disks.
Also, if you have two CD/DVD drives, try the other one.
Dec 04, 2009 | Microsoft Xbox 360 Console
My xbox won't read disk, nothing is wrong with the disks.
The reason that this happens is because the sensors on the back of the DVD drive have overheated.
When you overheat the Xbox it realligns the motherboard and the soldering gets supple again and will work for a little while, however this will not be permanent.
You will need to send it in to get it fixed or you can fix it yourself using a proven Xbox 360 Repair guide
Nov 28, 2009 | Microsoft Xbox 360 Console
Cannot get CD-ROM to work,to come up on screen.
Ok with that you need to insert the disc and then go into the my computer section of your computer and then in the CD rom drive you should see the disc and you will click on it to start the process. However if that does not work then your CD rom drive is defective and you need to purchase a new one.
Jun 17, 2009 | Computers & Internet
Inserting pc game and nothing happening, I have windows vista. I have tried putting in by run D;\set up still nothing
Have you considered that the disk may be faulty? This does happen from time to time, if other disks work in your drive and this disk is not picked up at all even if you check in 'My Computer' and nothing is displayed under your cdrom drive then the disk may be faulty.
Also if the game is written on a dvd disk and you are trying to play it using a cdrom drive and not a dvdrom drive then it will not work
Nov 25, 2008 | Computers & Internet
Dell inspiron 1150 screen goes black after standby
Let me help you regarding this, As your notebook is not having low room to handel the standby applications, i suggest you to change the power options in the control pannel. There you find POWER OPTIONS icon click on it and go to advance tab, there u find the option called WHEN YOU CLOSE THE LID, put it to DO NOTHING. So that nothing happens when you close the lid. I hope this helps you. BYE
Nov 14, 2008 | Computers & Internet
Can't read, burn cds
have you tried different cds? or just 1 same cd?
Oct 19, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
3,149 people viewed this question
David Payne
David Payne
