Question about Intel Motherboard
Stuck on asus logo on startup??
Recently changed over to a p5k mobo and a e8200 cpu, checked all other items are working (ram, graphics, soundcard).....but computer stays on the ASUS logo screen on startup and pressing 'del' does not go to bios?? help
thanks
Same problem here with my wife's Asus laptop. Called Asus and they said to unplug charger, remove the battery in the back, hold down the power button for 10 seconds. Then, replace battery, then charger, then press the power button and wait for startup. First time it got stuck at the windows loading bar screen for like 5 min. which is abnormal. Did a hard power down (press and hold power button til it shuts off) then restarted again. That time it worked and all is well so far. Could have been due to a static charge as she was on our couch with our dog backing up movies so charge might have entered through the CD/DVD drive opening. (?) Not sure, but if you are sitting on a static-prone couch with your laptop its probably best to sit on top of a bounce sheet.
Posted on May 31, 2010
    President:
  • 2,351 Answers
Reset / clear bios & remove the battery (check the voltage on batttery). Reseat & try again to enter bios. If you do get into the bios disable on screen logo. Still no good.
Call Asus 812-282-2787 Tech IL M-F 8:00AM to 5:0PM EST
Your call will be less than 5 minutes. Write down the S/N found on white sticker on pink port.
Mike
Posted on Apr 03, 2008
    New Friend:
    Problem Solver:
Your battery could be going bad. Remove the battery, plug in charger, press and hold power button until it turns on and then off, keep holding for ten seconds, then power on again.
Posted on Dec 14, 2014
  • Matthew Lynam
    Matthew Lynam Dec 14, 2014
Check unplugging the CD/DVD. sometime when is faulty either on desktops or laptops it will make it get stuck on the post cmos Screen or Logo.
Posted on Apr 02, 2009
Asus M4A88TD-V EVO/USB3 BIOS: 1702 AMD Phenom II X4 955 PSU Ultra 500watt ATX RAM Patriot DDR3 1600Mhz 2x4Gb Mobo will not POST, no beeps, fans turn for one second and stop. Mobo replaced with same,...
So you changed everything except 1 thing, power supply. Try another power supply or power suply cord.
If it doesn't work, try another graphic card, maybe there is some shor circuit.
May 07, 2011 | ASUS Motherboard M4A88TD-V EVO/USB3 AM3...
After connecting the sata hdd and the radeon hd 4870 graphics card populated all four memory slots I got no vga signal reminder and then the sys fans starts and stop continously. my power supply is a...
you will need to download the driver for the graphic card from the radon web site check the power supply wattage and if it is not at least 500 watts fit a new power supply
talk wit an ait repair shop for answers as you can explain and question as you go
Oct 25, 2017 | ASUS P5K3/P5K (P5K3 DELUXE/WIFI)...
Bootup
a bad power supply or a hairline crack in the mobo
Jun 04, 2009 | ASUS (P4BGV-MX) Motherboard
Recommended psu wattage inreplacement to 300watts psu for asusp4p800s-x
the needed wattage is directly linked to the componets you want to use other then the mobo itself. the main power surges are the CPU (takes 40 to 110 Watts) a graphics card (from 5 to over 150 Watts) the Drives (about 25-30 Watts eachs), the RAM and all the other addons and gadgets you build into your PC. Just add the different Wattages together and give it quiet some headroom. I usually drive this kinds of mobos with 400-550 Watts PSU to be on the save side, if i use a more or less "standard" graphics card, and even more with high sophistcated cards or lots of drives or such.
if you "see" low power (Volts) it might also be a problem with a partwise defective PSU.
May 28, 2009 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
PC wont boot, not even to bios
Maybe the mobo is shot for u and he has his PSU shot.......Check for any burnt smells from the mobo. See if the cable from the PSU is properly connected to the mobo. Try removing all drives like graphics cards, RAMS one by one and see if it works.
Aug 18, 2008 | ASUS P4S800-MX Motherboard
P5k motherboard
remove the ram, do you hear beeps?
you might want to get your hands on one of these
http://cgi.ebay.com/New-8digit-PC-Motherboard-CPU-Ram-Analyzer-Test-Card_W0QQitemZ190231285206QQcmdZViewItem?IMSfp=TL0806211611r25031
if link broken click here
Reseing the bios shouldn't be a problem go ahead, or is there something I don't know? does it void the warranty? I don't think so.
Jun 23, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Motherboard problem
Hiw can u say's its display problem,Have u checked the signals on k/b ?
If not check the Num lock status in keyboard. Press the Num lock key ,if the light glows and stands for sometime display is ok,but ur vga adapter is the problem.
Otherwise problem maybe with m/b or psu.
Pl check it.
Regards.
Was this soultion useful?give the apppriciation by rating it.
Apr 04, 2008 | ASUS P5K-V - Motherboard - ATX - iG33 -...
Asus a8n sli deluxe not powering up
do you have 2 sticks of ram in the pc?
if so try it with one in and do this with both
as in boot it with a single ram stick and try to determine if its a faulty ram stick
also if you can try another power sup unit
please let me know how you get on
Mar 22, 2008 | ASUS A8N-SLI Motherboard
I have a blank screen
so are you asking if there something wrong with your mobo?
if yes, try checking for the jumpers.
Jan 14, 2008 | ASUS P5N32-SLI Deluxe Motherboard
Winfast k8s755A freezes at startup
Ok I got e-mail from Foxconn and they told me to use a single sided 256 DDR RAM to get past post. So I did, then I wnt to BIOS and set all my settings, saved it restarted turned off the PC then returned my 1GB Ram then all worked just fine. This is an issue coused by haveing a Samptron 64 CPU.
Nov 21, 2007 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Intel Motherboard Logo
4,640 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
