When spinning, my Bosch Front Loader W/Machine's drum is spinning unevenly causing the machine to jump around the floor even though it is level. With a heavy load it is of course worse.
  • Washing Mach... Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on May 20, 2010
SOURCE:
Westinghouse front loader freestyle 700
either dampers have gone, its uneven (which i doubt after all this time) or overloaded
Sep 09, 2013 | Washing Machines
Machine has a bad vibration on the way to high spin, once there all is ok
The shock absorbers may need greasing, Put a bit of grease (the thick motor type) around where the smaller diameter part of the shock absorber enters the larger part, the take of the lid (isolate from mains) and give a a few hefty shoves on the drum downwards to help the grease to work in. Excessive knocking on the lead up to full spin could also be caused by an uneven load, the unit as a whole not being level or the unit being located on a joisted floor which increases vibration.
Hope this helps
Mar 27, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
My HOTPOINT ULTIMA WASHING MACHINE wt960 is very noisy on the spin cycles...is there a need for oiling or what else can I do..?
It could have an imbalnce in the drum because the load is uneven, or your machine could be uneven on the floor,, try checking for the level of your machine
Apr 17, 2011 | Hotpoint Ultima WF860 Front Load Washer
Whirpool top loader off balance in spin cycle
Your machine is probably not standing perfectly level. To level the machine, partly fill it with water. Make sure that the drum is standing in the middle of the machine and then adjust the machine until the water is at the same level all around at the nearest set of holes to the water. Check that the drum is still in the center of the outer drum. Make sure that the adjusting feet are all firmly on the floor and that you cannot rock the machine at all by hand. A top loader must be 100% level or it will shake.
Apr 03, 2011 | Whirlpool Washing Machines
Spin cycle loud maybe off balance
Apr 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Out of balance drum WM2277HW?
More than likely it did not get reinstalled right after the move. All four of the leveling legs must be firmly touching the floor. If one is even the thickness of a piece of paper off the floor it will start to rock during spin and the problem just amplifies itself. Make sure it's perfectly level and that all the feet are firmly on the floor.
Jul 28, 2008 | LG WM-2277HW Front Load Washer
New Bosch Front loader washer Maxx Classic WAE18060AU
Remove the 4 transit bolts from the back of the washing machine. These are supposed to be remove during installation. If they are not removed the machine jumps around like crazy on the spin cycle and the machine is almost unusable.
Jan 12, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
