Question about Mitsubishi WS-55859 55" Rear Projection Television
Picture not clear-double imaging streaks of green arcing across the screen
Double imaging of picture streaks of green arcing across the length of screen. This has started to happen gradualy and if i turned the TV off and back on it would fix it self....well not anly longer.
Anyone know what the problem maybe and if it is something that a somewhat hand person can fix. I'm not electrically hand tho!
    Champion:
  • 206 Answers
This is the most common problem with projection TV's, you have a convergence problem, Most sets will have two or three convergence Ic's your model only has one, the problem could be as simple as it has unsoldered itself and needs to be re soldered, or most likely it simply failed and needs to be replaced. If your handy with a soldering it is a fairly simple thing to do. The convergence Ic is mounted the the huge heat sink and has a part number on it of STK393-110 on the board its in location IC8C01, try re soldering all the leads first, if that fails the order Part# 267P155010 from www.vancebaldwin.com and replace it
Posted on Apr 02, 2008
Picture shows double images in red and green with red and green bands across the bottom of the screen
convergence ICs need replacement there are two STK392-110 Convergence ICs in that model, Also check the 2.2 ohm 2watt resistors there are 6 of them in that model.
Jan 22, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Hitachi 53UDX10B PICTURE DISTORTION
projection screens are prone to screen burn ,this is caused by the same image being displayed for a long time ie nick jr image in the corner,also check ther are no magnets close to the tv as this will cause distortion,ie speakers etc,hope this helps
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red and Green picture with ghost images
sounds like the high voltage transformer arc or one of the picture tubes arc causing the convergance ic to go bad
you can try to replace the IC heres a site to help:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
but you still may have a arcing problem.
Dec 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
Lost the picture
RESOLDER CIRCUIT BOARD LOOK FOR CRACK SOLDERING AT TRANSISTORS FOR CONVERGENCES
Oct 22, 2007 | RCA P56812BL 56" Rear Projection...
I have 47 inch with double color in picture, reds and green
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
PT-47WX, Blue streaks across the screen?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
During dark images on my TV, several green lines are visible across the TV.
You may have an arc in the screen and focus circuits. Water may have gotten into these circuits causing a delayed reaction. (Circuits Corroded). These circuits at least part of them are a part of the high voltage transformer (flyback). Your picture tube socket has spark gaps inside of it too which may be arcing. You need to have it checked by a tech to find out just what is arcing. Stargazer
Mar 11, 2007 | Samsung TX-R2765 TV
Mitsubishi WS-55859 55" Rear Projection Television Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
