Question about Canon imageCLASS D761 Copier
Error code E000 on a canon imageclass D761
Got code E000 on the copier, system failure fuser seems clear..
  • Anonymous Apr 14, 2008
    reading error code e000
  • Anonymous Aug 28, 2008
    ERROR 000
In service mode (additional function then pound sign) go to number 7 hit set go to 4 hit set push left arrow for yes set then unplug and replug
Posted on Jun 20, 2008
Cannon image class b 761 error 000 ? can u guys help thanks
Posted on Apr 17, 2009
Worked perfectly! Thanks!
Posted on Feb 16, 2009
    Problem Solver:
  • 14 Answers
Yes it worked like a ******* champ
Posted on Jul 11, 2008
My cannon D760 quit working. It flashes E000
if you are able to repair it.then look for paper jam in the fuser unit.E000 is related to fuser section
Jan 15, 2011 | Canon imageCLASS D761 Copier
System error 000
A E000 means that the fuser unit is not heating up correctly. You will most likey need a new fuser unit. If you unplug the copier and plug it back in and it will not come to "Ready" you need a new fuser. Good Luck
Jul 23, 2010 | Canon imageCLASS D761 Copier
SYSTEM ERROR CODE E000- HOW CAN THIS BE RESET? WHAT DOES THIS ERROR MEAN?
A E000, means that the fuser is not warming up correctly. You can try to unplug the copier and see if it will reset. If it will not reset, you will have to have the fuser unit replaced or the upper fuser heater unit and film. Good Luck
Jul 21, 2010 | Canon imageCLASS D761 Copier
Solucionar el error de systema E000 en mi fotocopiadora imageCLASS D761
Problem on Fuser unite.
Please check fuser lamp or fuser fuser cover.Check power supply heater fuse.May be problem two things.
Jan 25, 2010 | Canon imageCLASS D761 Copier
System Error E000
This is usually a fixing heater fault.
The heating element in the fixing assembly (the hot rollers) has probably blown.
It can also be caused by a faulty thermal sensor, or a circuit board, relay or DC Controller.
If you are not competant at repairing copiers, you should have a service technician fix this.
The error cannot be cleared until the cause of the fault has been rectified. This is a safety measure to prevent overheating problem and further damage. The technician must clear the error in 'Service Mode'
Dec 21, 2009 | Canon imageCLASS D761 Copier
System error E000
E000 0000 The reading of the main thermistor does not reach 30oC 1 sec after the main power switch is turned on. Or, it does not reach 70oC 2 sec thereafter
Nov 03, 2009 | Canon imageCLASS D761 Copier
Canon Copier Imageclass D761 - System Error E000
Try this one from Canon's website:
Issue: ERROR LCD: System Error E000
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
May 10, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon imageclass d761 error code
additional function them the pound key, with the arrow look for the printer setting, hit the set key go to printer reset, hit the set key it will ask you yes or no press the left OR (YES) the printer will not do anything unolug them wait 3 second and plug it back it if this doesnt work you will need to have the fuser replace
Aug 24, 2007 | Sharp AL 1631 Copier
Canon imageCLASS D761 Copier Logo
1,123 people viewed this question
old marine
old marine
